Home > Technical (L322) > New owner with a load of problems to diagnose |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
After checking & clearing codes with hex helping me out with the fault reading, we got two main faults. One was the gearbox selector switch, which is what triggers the "Trans fail safe prog" when you go to reverse/park to drive etc. The other code given was "ambient temp sensor" & the car reads -40c outside.
20th Mar 2015 8:38am |
Ok so far seems I need to get the inhibitor switch for the gearbox as it just keeps going into "trans fail safe" everytime I go from park. I then put it in neutral & turn it off & on, then its fine. Also the oil leak is coming from both vanos seloniod gaskets. So they are my first two jobs. 2004 RR 4.4 V8 Autobiography |
31st Mar 2015 6:57pm |
jdig Member Since: 12 Mar 2015 Location: england Posts: 12 |
Was the car ever towed?
31st Mar 2015 10:35pm |
I've never towed it, Im sure I've read about this fuse 37. What's it's all about? 2004 RR 4.4 V8 Autobiography |
31st Mar 2015 11:52pm |
Yes I had that message, I'll check it out later after work. 2004 RR 4.4 V8 Autobiography |
1st Apr 2015 8:47am |
No fuse in slot 37. 2004 RR 4.4 V8 Autobiography |
1st Apr 2015 6:10pm |
