Home > In Car Electronics (L322) > Bluetooth retrofit |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Sorry i didnot mention car is l322 04.Can i use the bmw loom or i have to buy tel wiring loom for the l322 and make the necessary repinning???
1st Apr 2015 11:58am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
The plug in the boot needs to be repinned. I wouldn't take the chance of plugging the BMW loom into it just in case. |
2nd Apr 2015 12:38am |
Noddy good day and many thanks for your reply. |
2nd Apr 2015 9:30am |
ok i am in search of rr telephone loom.I have found this
2nd Apr 2015 11:55am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
The voice loom was a separate option on the rr, but was integrated into the ULF on later bmws, so you don't want an RR telephone loom. If your ulf says "mit ses" on it then it will do voice commands over the normal telephone loom.
2nd Apr 2015 5:46pm |
mjdronfield nice to hear from you since i have seen that u have also fitted ulf.
3rd Apr 2015 9:50am |
mjdronfield hi again from an internet search it seems,accg to diagnosticrepair.blogspot.com which redirects to bmwtips.com, that the bmw x400 connector has the exact same wiring with RR as per the attached.Whenever u have time can u please have a look and let me know. |
3rd Apr 2015 10:37am |
sorry not attached.trying to find a way if can attach it the drawings. |
3rd Apr 2015 10:39am |
ok hope here is it.
3rd Apr 2015 10:42am |
Hi,
4th Apr 2015 7:04am |
Pin 17 is the voltage feed. That is where it needs to be for the ULF, so have a meter on pin 17 and pin 36 and you should have a 12 volt feed. (or thereabouts).
4th Apr 2015 1:04pm |
Mjdronfield GOOD DAY.Not any further need about bmw wiring since yday i decided to look for the x400 connector and much to my surprise i saw that car is already prewired.So what i will only need is either to repin 54 connector or much better for me to buy an adaptor. Any idea where can i find/buy such an adaptor???
6th Apr 2015 9:52am |
Hi,
6th Apr 2015 12:56pm |
Ok ok thanks for your reply.Have seen drawings for rewiring the 54pin so no need to post them again.
6th Apr 2015 1:57pm |
