Home > Maintenance & Mods (L322) > Heated Seat. |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Can't those with warm hands warm up those with a cold bottom? |
19th Jan 2015 12:42pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1663 |
Interesting - I bought my 2010MY 4 days ago and have been back to question them on it. To me they hardly heat up at all to be honest...
19th Jan 2015 8:37pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3656 |
I'm just gonna bump this to see if I get any answers. My 2010 seems to have an intermittent fan under the drivers seat, it's quite handy that you can just stick a finger in to see if it's spinning. Has anyone else had this? Is there a fix? Does anyone have the circuit diagram - or is there one in/on TOPIX.
23rd Jan 2015 6:13pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
Geoff,
26th Jan 2015 10:07pm |
Ah well, I found that as I can feel the fan under my seat, the filter has fallen off again, and if it doesn't start spinning on switch on I turn it of and turn it on again - the trick seems to be to turn it on slowly.
26th Jan 2015 10:41pm |
Sometimes the turning off turning on trick doesn't work in which case I have to turn off and turn on the car (restart) after a few miles as the IIDTool pointed me in the direction of the drivers seat heater losing contact (or maybe never even making contact) with the appropriate ECU.
8th Feb 2015 11:23am |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 |
I'll swap my 2003 for your 2010 if you like. My seats heat up super quick! |
10th Feb 2015 2:02pm |
Lanby Member Since: 16 Jan 2013 Location: Leeds Posts: 11 |
Supershuttle, did you get a resolution to your heated seat problem as mine has started doing the same?
5th Apr 2015 10:14pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4252 |
Craig Are these the filters? https://www.island-4x4.co.uk/seat-filter-g...36870.html How many per seat? 1 or 2? Your post suggests 2per seat Ta Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 on order. 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
6th Oct 2018 9:50pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
Thats them Rob, two per seat sir... One in the base and one behind the map flap in the back |
6th Oct 2018 9:53pm |
Cheers! I’ll check out the front 2.
6th Oct 2018 10:01pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
A bit of light reading for you here Dr Rob:
6th Oct 2018 10:10pm |
