Home > Maintenance & Mods (L322) > Battery drain in amps (update)
kay
My battery goes flat after a week with nothing turned on what should the amps drain be in amps I have .06 amps does anybody know what it should be?
thanks Kay
Post #32125 17th Oct 2010 8:13pm
i'm sure i've seen some posts re this somewhere on the forum....have you done a search? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #32159 17th Oct 2010 9:27pm
kay
Yes I did a search but no result on what it should be
Kay
Post #32179 17th Oct 2010 10:22pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
i would be interested in answer to this aswell, mine only draws between 40 and 50 milliamps fluctuating but it too drains the battery and only just starts after 5 days. my local says it should draw less than 30 milliamp but a quick search on the net and i came across a few people saying a sleeping bcm draws 40 milliamps, confused. i went through all the fuses one by one and none of them made any difference to the power drain in a positive way, i even disconnected the satnav and it still draws the same power.
Post #32186 18th Oct 2010 12:32am
RRCanuck
Canada 2010 Range Rover Supercharged Supercharged Santorini Black
hello. I can only speak from personal experience having had these issues as well. There may be other solutions but what worked for me was simple and inexpensive. Buy a good battery and have a "battery tender" (not a recharger, a tender) PROPERLY installed. When you know the car will be sitting for a few days, simply plug it in. Fully healthy battery = happy RR, IMHO. Wink You may also find this helps with other "gremlins" as well. I have Thumbs Up
mike.
Post #32187 18th Oct 2010 4:02am
Kay
i found this whilst searching , close to problem you have..
http://www.fullfatrr.com/forum/topic466.ht...tery+drain
or..
http://www.rangerovers.net/forum/viewtopic.php?f=2&t=19826 ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #32196 18th Oct 2010 9:12am
SteveMFr
Site Sponsor
I don't know if there is an 'exact' figure for at-rest draw on the battery in the FFRR - it would vary dependent on equipment levels. I've never seen one.
A bit of math makes this problem easy, tho: at 50mA draw, the RR uses 1.2A over 24hrs (50mA/h x 24h). The battery in the RR is between 90 and 110aH depending on model and spec. After 5 days you've used 6A, after 25 days 30A. The motor should start with 60aH left easily - even on the coldest of days.
It used to be that simple cars with electric clocks and maybe an electronic radio with a memory used 10-20mA at rest. Add an alarm and under 30mA is fine - but is virtually no difference to 40 or 50mA. The RR is not simple, tho, and the P38 was somewhere around 60-80mA. I'd think that the LM has improved as far as electrics go and draws less, but I wouldn't worry under 80mA. And even then, the car should start fine after 5 days (your RR should be fine after 5 days even at 300mA draw - tho this would def not be normal).
The trouble is, you're only seeing a snapshot of what happens over 24hrs. This is where the difficulties lie. Finding a constant draw is easy but finding an item that draws every now and again is much more difficult.
I'd suggest starting with the simple causes and checking the battery before moving on to more complex searches.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #32233 18th Oct 2010 1:59pm
mzplcg
The figures quoted for the battery are when it's new. A 3 year old 110aH battery is going to be more like half that in reality.
Try leaving the headlights on for an hour and see if it starts then. It should do if the battery is in good nick but I think you'll find it won't. Lights & Ignition etc should draw about 20 amps which would take 20aH out which would leave plenty to start the motor.
If you have to replace the battery, get the best you can find. Winter's a cummin' and that's hard on a battery.
Dom.
Post #32253 18th Oct 2010 4:22pm
kay
The drives door central locking doesn't seem to work at the moment like its stiff would this be the cause of the battery flattening
Kay
Post #32328 18th Oct 2010 10:41pm
mzplcg
Unlikely. Even if it were to draw large currents due to being stiff, it would not operate for long enough to flatten the battery.
Do yourself a favour and get the battery tested. That way you'll know for sure if it's just a weak battery.
Post #32353 19th Oct 2010 7:25am
kay
Fitted a new battery 110ah bosch the battary is still loosing charge just lasting longer, so there is a drain somwhere. Now its frosty at night the screen is frosty but the O/S is clear over where the dials & steering wheel is does this show where the fault is
Kay
Post #35326 9th Nov 2010 12:11am
mzplcg
If you're saying there is a part of the windscreen which looks like the heated screen elements have been on ------ they probably have been on (unless you have nice kind Pixies defrosting your screen) and they have mahoosive current draw. Much more than the heated rear window as there's a lot more element wires.
Easiest way to prove is to remove the fuse which protects the heated front screen and see if it still happens.
Dom.
Post #35349 9th Nov 2010 10:22am
if its the heated front screen thats on all the time then logically the whole screen would be defrosted..i suspect something around or in the speedo part of the dash is generating just enough heat to clear the part of the screen, i cant think what it could be . ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #35351 9th Nov 2010 10:30am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Logic has nothing to do with it! Shocked
IIRC, the screen has a left and right circuit (perhaps a middle one too). When the screen on my D3 failed it was clearing one side but not the other. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #35364 9th Nov 2010 12:15pm
SteveMFr
Site Sponsor
Re: Battery drain in amps (update)
thanks Kay
That would be 6/100ths of an amp - or 60/1000ths which = 60mA. This alone will not be causing the problem on a new 110aH battery.
I wouldn't think its your windshield heater - your battery would be dead after a night (is the section of defrosted windshield really clear top to bottom with sharply defined lines to the R and L? The screen has a L&R circuit - in theory it could be a stuck relay on one side. But even 1/2 of the windshield heater draws too much current for a week.)
As I said, when you connect an ammeter to the vehicle you are only seeing a snapshot of what happens. In the worst case, you'll need a logging ammeter connected to the car for a longer period.
RF interference is a possibility - even on the MKIII (it's common on the P38). Does this happen everywhere you leave the car parked (or do you always leave it in the same spot)?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #35368 9th Nov 2010 12:27pm
