Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
Kaj, If it still has the aluminium box with fins attached then that is a soft start relay, this is the diagram for it
Brown/Green is a permanent 12v supply rated at 80amps White/Green is an ignition 12v supply rated at 15amps Black is an earth, should be the same size wire as Brown/Green White/Blue is the control wire, I used a generic fan controller with a take off from the top hose I fixed the fan to the rad with cable ties, drilled two holes through the top edge of the radiator in line with the two plastic hooks, and used cable ties to hold them in place. I cut off the top two side hooks as the bottom side mounts are in the same place as two plastic retainers for the original fan shroud I drilled two holes through the fan fixings and used cable ties through the fan shroud and around the plastic lugs on the rad. I used a meter to find an ignition switched live in the ECU box...
PM sent sako243, yep, they are pretty unstoppable offroad, I've embarrassed a few Defenders....... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- Last edited by Haylands on 4th Jun 2022 12:24pm. Edited 1 time in total |
26th Dec 2014 6:46pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
I've yet to get to grips with it on slippery wet grass / mud. Too much weight and not enough tread but then I do have ATs on rather than than those fitted to the Defender...
Having had a look under it in the pit last night I seem to have demolished the skid plate underneath the sump so maybe time to invest in a bash plate. Might ask the local trailer company if they can build one - knowing their workmanship it will be a damn sight cheaper, easier to source and better quality than most available. Regards Ed |
27th Dec 2014 8:35pm |
Went for it's MOT today, had it nearly a year now and done 16,000 miles in it, taken it swimming and mountain climbing, driven it like an old granny and sometimes like I stole it....
3rd Feb 2015 9:52pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7636 |
That's impressive Pete.
3rd Feb 2015 10:37pm |
Mark,
4th Feb 2015 8:10pm |
Just updating this thread and keeping everything in one place...
21st Apr 2015 11:32pm |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 |
That fix looks first class |
22nd Apr 2015 9:32am |
well done Pete MY 2010 5.0 SC Galway green and sand interior!!
22nd Apr 2015 1:51pm |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
Does the 32" wheel fit in the spare wheel well? |
6th May 2015 10:38am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Top job on the seat Pete, funny how they all split there! If it dont work.......burn it!
6th May 2015 10:44am |
Chex, I don't know mine is full of LPG tank... I would imagine it probably wouldn't, the normal one looks tight enough...
6th May 2015 11:04am |
Thanks for getting back to me |
6th May 2015 6:42pm |
Haylands are you still running without a thermostat? Any problems? |
11th May 2015 5:18pm |
Ran it for a few months without one, didn't seem to mind, then it started getting colder so I fitted an 80deg one.... Pete
11th May 2015 10:05pm |
