Home > Maintenance & Mods (L322) > Trans failsafe prog |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Mine did that repeatedly before it started locking in 4th, then.... new gearbox...
23rd Apr 2015 9:13pm |
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 |
that does'nt sound to good but I've just turned 102,000 so wouldnt be surprised according to all I've read.
24th Apr 2015 7:38am |
Ok here goes... Went to Indy today and plugged in, no gearbox codes at all but lots of transfer box codes, cleared them and went down the road, stopped selected reverse BONG got the message again so straight back to garage plug in and again no gearbox codes but 2 transfer box codes which are.....
24th Apr 2015 4:14pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
As you are not changing from high to low ratio, there is no logical reason why the transfer box is firing codes and faults at you, but it does.
24th Apr 2015 5:07pm |
Thanks for the reply a few things I can try, first being hi lo switch a few times then try disconnecting the lead from motor, I'm not a mech but I'm sure I can work it out, will report back after giving it a go tomorrow |
24th Apr 2015 6:04pm |
I'm still driving it is this ok?. |
24th Apr 2015 6:09pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
Certainly sounds like your transfer box shift motor potentiometer is playing up.
24th Apr 2015 6:13pm |
Cheers Phil , is this a part that can be changed? |
24th Apr 2015 6:33pm |
No, AFAIK, unless the guy on landrovers.net has finally come through with his re-manufacture.... .
24th Apr 2015 10:45pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
I had exactly the same with my TD6.
When I unplugged my TSM. I would get the dash TFSP message at every ignition on / start but only the once and then it would go and not come back.
Yep - I can second that!! As per this video, I took my TSM off, put 12V to it and let it run for 5 minutes. It never actually worked after than in terms of shifting between low and high ratios but equally it never threw another dash fault either! Other things to consider are battery and / or alternator charging fluctuations, sometimes they can throw a fault on these very voltage sensitive cars. 2006 4.2 SC 2019 Renault Zoe Dynamique Nav |
25th Apr 2015 11:49am |
Well its intermittent at the moment, so took a chance and tried changing from hi to low a few times and All works at it should
25th Apr 2015 1:51pm |
Well after a couple of months the dreaded message is back! Stil driving and changing gear nicely sometimes hi to lo works other it doesn't ignition off and on again and all is well apart from constant messages.
3rd Jul 2015 7:35pm |
Well tried a lo-hi today just left with lo range flashing on the dash and selector doing nothing and stuck in lo, with a bit of messing,...eventually it did work and with the transfer motor running for about 10 seconds + it clonked back in hi range and thats where it'll be staying!! gears still change perfectly still so i guess my transfer motor is goosed? |
6th Jul 2015 8:57am |
