Home > Maintenance & Mods (L322) > Door fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7948 |
It's all in one unit with the lock, I picked up a second hand one of "ia dora" (good seller of FF bits) on eBay for £34 delivered, doesn't take long to fit and works great now.... Pete
27th Apr 2015 10:19pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1663 |
something like This ..? Ash
29th Apr 2015 9:32pm |
trickymickey Member Since: 28 Mar 2014 Location: Worksop Posts: 46 |
Thanks for that , ordered one from Furness £34.00 . |
29th Apr 2015 11:48pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
Have a read of this thread then if i were you, i would not lock my car again until replaced!
30th Apr 2015 9:33am |
Well after disconnecting battery (wary of airbag ) and waiting awhile , stripped doorcard off and proceeded to pull old latch out . A bit of messing about ! finally got old latch out and built new one up with cable for door pull and top button, took grommet out to pull key lock on outside. Second hand latch was loosely screwed to door , then i re eentered the key part on the outside of the door into the latch, and tightened the retainer for that bit up. Finally tightened latch and reconnected battery. Lock mechanism worked up and down off fob , but shuddered a bit , thought this might be because the door was open....so shut the door .Locked the door and it wouldnt open again .... Panic , so i disconnected battery again . After a quick cuppa the battery was reconnected and normal service resumed .....Phew !. Fuse 24 apparently will do the same trick, hopefully this will now prove to be reliable ! |
1st May 2015 6:04pm |
Sorted now, that's the main thing... Pete
1st May 2015 7:37pm |
