Home > In Car Electronics (L322) > Final Attempt to Get Bluetooth Phone Working |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Bump - anyone??? There is a difference between knowing your sh!t and knowing you're sh!t
23rd Apr 2015 12:49pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 340 |
The IIDTool stores your original settings (for CCF etc) so you should be able to restore all settings to 'normal'. This may mean that some of the changes to the CCF that you wanted will revert back but hopefully the blutooth will as well and you can then update the CCF for the others that it blanked. |
26th Apr 2015 6:50pm |
I restored the CCF setting from my IDD but the bluetooth settings did not change (some others did) but none of the restores I tried put it back to the way it was when purchased (i.e. alarm still chirps and key does not bong which they did originally when purchased).
1st May 2015 12:34pm |
Bump anyone able to say if these are the correct settings and if they are anything else to check to see where the problem might be.
11th May 2015 5:05pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
It might be worth reflashing the bluetooth module. You can do it with your Gap iiD tool. Details are on their website IIRC John
11th May 2015 5:11pm |
Would really like to get the phone working if anyone can please have a look at the CCF files related to the phone and bluetooth and tell me what they should be.
12th Jan 2016 6:13pm |
To reflash the software, IIRC, you need to install the "Special" Software from the Gap web site. Once done you then revert to the current standard software. It's a while since I did it so can't remember whether Gap authorised or whether it was just accessing your account and installing.
15th Jan 2016 8:10pm |
