Home > Maintenance & Mods (L322) > issues with my 2003 4.4 v8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7927 |
I don't think new discs will sort out a sticking caliper...
2nd May 2015 10:01pm |
bag 933s Member Since: 21 Apr 2015 Location: south west Posts: 13 |
hi pete, i have bought the new discs as one side is badly scored so when i have them stripped down ect i can just fit new parts, its the main fan at front of engine...... |
2nd May 2015 10:06pm |
i have read so much on the lumpy running, i cant say its miss firing, i heard could be torque converter, coil packs ect, its just at that speed you wsnt to cruise on the motorway also, has anyone else encountered this? |
2nd May 2015 10:08pm |
it has a full service history 104,000 and i had it fully serviced before purchase |
2nd May 2015 10:09pm |
I'd start with a full 4 wheel laser alignment and wheel balance and take it from there...
2nd May 2015 10:41pm |
thought i would update this, new discs and pads fitted to the rear, we managed to find the cause of the irritating wobble when driving, it was 4 x 5mm cast spacers one on each wheel......had the mot done straight through and no advisories |
24th May 2015 4:39pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
If you're talking about the fan 'inside' the engine bay, then this is a viscous fan, it spins all the time. However with the engine off and a cold engine you should be able to turn the fan freely by hand. When the viscous clutch in the hub gets hot it locks up and drives the fan harder.
24th May 2015 7:04pm |
