Home > My Range Rover > 2002 L322 Java black - photos |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2282 |
handig!!!! Pietertje.... Looks good |
4th May 2015 1:42pm |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 |
Thanks! How does the old chip align in the new case? Since the set up of the buttons is different from the old key. Also, you think this case will work as well? http://www.ecuobd2.com/trk-land-01-433 L322 Vogue 2003 |
10th May 2015 2:05pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3199 |
There is a little slot down at the blade end and the chip fits into it. When I got the key there was a small piece of silicone in the slot which you remove and then use to secure the chip in place. It was just like a small bit of soft sticky rubber and can be easily replaced if your key comes without one.
10th May 2015 4:06pm |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
@ starberg. Weegie is Right, there was a topic here with lots of photo's. I Think the key in the link should work as well since it's the same as the key in this topic http://www.fullfatrr.com/forum/topic8500.html 2002 L322 V8 |
10th May 2015 6:53pm |
