Home > Wheels & Tyres > There's a hole in my wheel |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Went to go out this morning and did the usual quick glance to make sure that I had 4 wheels and that they were round, which they were, and went on my merry way........
4th May 2015 9:05pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7797 |
Shame you don't know anyone with a spare set in his shed ....... |
4th May 2015 10:02pm |
Are but I do, me Only they haven't got the centres Yesterday I couldn't spell Engineer... Today I are one!
4th May 2015 11:09pm |
Mrmerlin, thanks for your words of wisdom, however I have gone down a slightly different route. I had the spare set of rims, that were in my shed, re-furbished, removing all signs of corrosion and making the wheel caps fit nice and snugly Yesterday I couldn't spell Engineer... Today I are one!
19th Jul 2015 11:26pm |
Mrmerlin Member Since: 21 Mar 2013 Location: Aurora Colorado USA Posts: 13 |
thats good that you got the corrosion removed,
20th Jul 2015 4:34am |
Now there's a good tip if ever I herd one
20th Jul 2015 12:06pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
coat the mating face of the wheel with copper grease, and it stops it corroding to the hub. It's even listed as part of Land-Rovers service schedule. |
20th Jul 2015 2:31pm |
Done that one already, but the salt water can turn it quite quickly into a dry corroded mess, as they regularly say, at least 4 times an hour, on commercial TV, every little helps....... Yesterday I couldn't spell Engineer... Today I are one!
20th Jul 2015 8:35pm |
it depends on the quality of the grease used. Some of the cheaper ones have more grease than copper, which just washes off leaving hardly anything on the mating face. But even when dry the copper prevents the wheel and hub welding themselves together. |
20th Jul 2015 8:48pm |
even if you use grease your all missing the point,
20th Jul 2015 9:10pm |
unless you silicone the wheel onto the mating face of the hub it will still corrode onto the hub without grease. The corrosion will then spread up the centre of the wheel. |
20th Jul 2015 9:26pm |
I think that a combination is the best way to go, in my experience, when a wheel corrosion welds' its self to the hub, most of the corrosion is around the centre of the wheel. Therefore I can only conclude that it has been due to water ingress past the centre cap, so sealing that point of entry up makes sense. However this is not to say that copper slipping the hub should be ignored, because if the wheel were to corrode on from the outside, it will result in sledge hammers at twenty paces
20th Jul 2015 10:27pm |
