Home > Maintenance & Mods (L322) > Removing Window Tint Film
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
How hard is it to do? I'm pretty certain that my windows have been tinted beyond factory spec, and its a bit too dark for my liking.
I don't think the fronts are illegal and they are visibly lighter than the rear, but I'm not a drug dealer or a celebrity, and one of the attractions of a car with lots of glass area is that it should be nice and bright!
Is this a DIY job or a whole world of pain and suffering?
Many thanks
MW
Post #328032 15th May 2015 10:39am
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
It can be very tricky I've heard of some tinting company's charge more to remove old tint than to apply it ! But give it a try on a hot day sometimes you can be lucky and it comes off without leaving any glue. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #328034 15th May 2015 10:45am
Andy B
I read online that you can use a household steamer to remove it. Maybe worth investigating further. It looks a right Censored to remove razor blade or similar Big Cry SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #328036 15th May 2015 10:59am
fairly easy job using a hairdryer or heat gun.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #328037 15th May 2015 11:11am
You just need to get a corner free by the use of a craft blade and usually you can just pull it slowly off.
You will be left with a glue residue on the glass which you can remove with hot water.
Bit of a messy job but not difficult.
Post #328038 15th May 2015 11:12am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Hair dryer, simples and wont leave a sticky residue too, also do on a warm day to help and go slowly while pulling the tint off while heating the tint, easy 10/15 min job if do slowly....or if you rush and leave the glue on the glass will take 20/30 min to clean...or longer Whistle If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #328040 15th May 2015 11:30am
Discotigger
Edd China removed the window tints off the Desoto car he was working on on last Monday's Wheeler Dealers. Watch the episode and it'll show you the tips on how best to remove the tints.
Heat gun / hairdryer and craft blade is all you'll need.... and some patience. Thumbs Up
Post #328045 15th May 2015 12:34pm
mike whiskey
Thanks for the advice folks.
Front windows done last night. I was too impatient with the drivers side, and pulled the film too quickly, resulting in lots of sticky residue. After trying several cleaning products, I discovered that petrol wiped on with a rag would soften it, and then i could rub it off with a clean rag.
The passenger side i took more slowly, more heat (Had to wear gloves to protect my fingers!), and it came off cleanly with only a few marks, which again were removed with petrol and a rag.
The environment inside is much improved. I will wait and see if I can leave the rear, or will have to do more.
MW
Post #328762 20th May 2015 1:00pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Friend of mine had an Audi Q7 which had dark tints on the rear and rear side windows. It was parked in a secure car park in Manchester last year while they went Christmas shopping. When he returned his rear side and tailgate windows had been smashed. When the police turned up they said it was because of the tints, the yobbos think that there is something valuable in the car because it's hidden, and just put the windows though on the off chance!
Post #328763 20th May 2015 1:10pm
mike whiskey
Just to close this down, I'm going to leave the rears for now. I don't really notice them when driving, except at low light when the extra darnkess in the rear view mirror is slightly oidd, but once properly dark its not a problem.
I'm certainly not going to risk peeling off my heated rear window though!
MW
Post #330577 2nd Jun 2015 1:16pm
Good point about the heated rear screen! Shocked Shocked Shocked Whistle
Post #330687 2nd Jun 2015 11:50pm
Zirconblue
It's probably not worth bothering with the side boot windows either, as they have your TV and radio aerials on them.
Post #330696 3rd Jun 2015 12:25am
