Home > Technical (L322) > Broken driveshaft circlip
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Was driving along, stopped at a set of lights and lost all drive. Got it recovered to my home by the AA to find that the nearside front driveshaft was part out of the diff. Stripped it down and found that the circlip that retains the shaft in the diff was broken in two pieces. How can that happen? I have had the car about three years without having a problem in that area. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #328477 18th May 2015 5:42pm
RRPhil
You are not alone ...
Phil
Post #328542 18th May 2015 11:09pm
Are they all the same? I have a few used ones here if you need parts?
Post #328549 18th May 2015 11:49pm
its me
Craig, Thanks for the offer. I rang local Land Rover agent (Hunters) to put one on overnight delivery. They called me back five minuets later to say they had one in the bin. £2.13p and hopefully problems are over.Just about to refit the shaft now.From what RRPhil has posted it has been a problem in the past but I can't understand how the circlip can break. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #328565 19th May 2015 8:45am
No worries, was unsure if you could buy just the circlip sir Bow down
Glad your getting her sorted Thumbs Up
Post #328572 19th May 2015 9:17am
Check engine mounts are in good order and make sure there is nothing else that could have caused the circlip to pop.
Post #328581 19th May 2015 10:03am
its me
The circlip didn't pop. It was in two halves and so it had no tension. The circlip is oval shaped so once broken there was no tension in it. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #328601 19th May 2015 1:05pm
