Home > Technical (L322) > No throttle response |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Any faults flashing up?? |
22nd May 2015 7:38pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
The throttle pedal is just a switch, it has no cable, if it felt funny then maybe it's a fault in the pedal itself Pete
22nd May 2015 8:18pm |
Maxum Member Since: 26 May 2014 Location: Staffordshire Posts: 7 |
Hi. No lights nothing when I press the systems check button. |
22nd May 2015 8:24pm |
Hi. The feel was as if I had resistance and it would accelerate. When it failed I lifted off pedal floored it again and no response from the engine just Erving at high revs and no gear change. Foot off completely let it slow the revs back then start again this time acceleration it's as if the engine was restricted. |
22nd May 2015 8:28pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
It's not completely clear to me what you mean when you write no response from engine, but at the same time it revs high and no gear change.
23rd May 2015 8:16am |
Hi
23rd May 2015 8:26am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Which also suggests a fault with the accelerator pedal switch. |
23rd May 2015 12:33pm |
The no resistance issue on the pedal would indicate to me that something in the pedal is sticking. Essentially the potentiometer in the pedal is giving the signal to the ECU and if the potmeter is not moving, then the ECU is not changing whatever it is doing. So my guess would be something in the pedal is sticking.
23rd May 2015 12:39pm |
Dead easy to replace, broke my old one when my foot slipped, can't remember how much but wasn't too bad |
23rd May 2015 1:49pm |
