Home > Maintenance & Mods (L322) > Td6 exhaust upgrade |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
I understand if you decat it, it smells like an old ice cream van if you are near the exhaust.
27th May 2015 2:24pm |
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 |
Problem with a diesel is that it will still sound like a tractor , even if in this case a Chelsea tractor ...... Jaybear
27th May 2015 3:16pm |
Can't hear my Chelsea tractor, as I have had the amp upgrade done and like my music 2011 Range Rover Vogue SE 4.4 TDV8
27th May 2015 3:33pm |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
De cats make them stink, sitting in traffic with the windows down is vile.
27th May 2015 6:17pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
And if you De cat it you'll have mot issues un less you swap it back every time If it dont work.......burn it!
27th May 2015 6:40pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Actually my mate put a performance exhaust on his TDi Seat. It had no cat or silencer boxes in it. It's wasn't noisy at all! All you heard was a bit more turbo whistle.
27th May 2015 8:24pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Mine passed its MOT without a cat this morning |
27th May 2015 9:22pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
IMO on a TD6 it is just not worth the effort or the expense.
27th May 2015 10:56pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
TD6 will stink without a CAT sir... A younger customer of mine had it done and it slowly smokes everything out!!! |
27th May 2015 10:57pm |
It will still pass the emissions test without one. However the tester is also supposed to visually check to see if a Cat is present, if the car had one when new. So it depends if he or she notices. You can also get decats that look the same as a real Catalytic converter, the tester can't check the inside. |
27th May 2015 11:00pm |
