Home > Technical (L322) > Breakdown - Mass Air Flow Sensor? (Update - Blown Turbo!) |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Just getting off M25 yesterday after an hour on the motorway without problems or symptoms. Tried to accelerate up the off ramp. Load 'pop' sound then no acceleration and wouldn't go above 30-40mph. Whilst running it is very smooth. Just no acceleration.
24th May 2015 7:14am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1699 |
Still sounds like a turbo hose. It would be worth taking the hoses off, and checking them fully |
24th May 2015 7:34am |
Thanks Mikey.
24th May 2015 8:01am |
That's not so good then
24th May 2015 8:43am |
If you unplug the MAF sensors the car will still start and run smoothly but will NOT have any power or go over about 20 mph. (Your symptoms) Not sure if this helps you though. I presume the airbox/filter and pipes are all secure and not split/loose. |
24th May 2015 9:17am |
Interesting. So it could be the MAF Sensor after all and unplugging didn't help diagnose the problem? I guess I just have to wait for the dealer to find the time to look at it and hope for the best Any idea if MAF sensors are covered under the extended warranty? Thanks for comments 2012 5.0L S/C
24th May 2015 9:22am |
They are only about £75 each and take 5 minutes to fit but they rarely just stop working so it may be something related. An air leak seems most likely. |
24th May 2015 9:33am |
Thanks. I'll just have to wait and see what they come up with. Just passed the dealer this morning and by coincidence my RR was being unloaded by the AA having spent the night at Fleet Services. I'll have to wait a few days for the diagnosis and will update then. Cheers. 2012 5.0L S/C
24th May 2015 2:37pm |
Just got the call from the dealer. It's a blown turbo. Probably £2,500. Hopefully it will be covered under the LR Extended Warranty. As it's over £2,000 they will probably send someone to inspect. Fingers crossed...... 2012 5.0L S/C
27th May 2015 3:59pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I don't see why it wouldn't be covered. Even the cheap ones cover major components like a Turbo. |
27th May 2015 8:20pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
29th May 2015 10:53am |
Loud pop then no acceleration. Black smoke later but didn't notice it at first. Still waiting for warranty confirmation 2012 5.0L S/C
29th May 2015 11:37am |
marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141 |
Hi Nomad, is your MD Westover Christchurch or is there one in or around Ringwood? I am in Christchurch and have been using Westovers and cannot seem to find a local LR indy.
29th May 2015 11:54am |
I've been using Westover for years. Overall I'm happy with their service. Recently I've been using BLR, an Independent on the way to Poole, for oil changes etc. So far so good. They are always very busy which is a good sign.
29th May 2015 10:31pm |
