![]() | Home > Technical (L322) > P-2462 Ranger Rover Air Compressor Tube Diagram |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7962 ![]() ![]() ![]() |
6mm O/D plastic pipe (they use it a lot on trucks) and a 6mm pushfit straight connector and you can replace the melted bit, unless it's the fat black pipe, in which case, measure it and see...
Saintsing1 Member Since: 29 May 2015 Location: Las Vegas Posts: 3 ![]() ![]() ![]() |
Thanks for the tip. I think I found the tubing.
Haven't seen a diagram with the full layout, basically a pipe from the pump to the sill tank, then a pipe to the valve body in front of the tank, four pipes to the airbags that go through articulation valves in the front and rear arches...
This is the pipe... 6mm outside diameter
Thanks for the tips! I'm thinking a local hardware store may have the pipkng, but I can order on ebay if I can't find it.
Oh right... here you go then....
