Home > In Car Electronics (L405) > DashCams
I mounted mine here - it's to the left but seems a wide enough field of vision & I can't see it Very Happy
the cable then just pushes up into the headlining - no effort or tricks - I just tucked it in - then ran it across the top of the pillar air bag - big screwdriver to lever it open just enough to tuck the cable in -
Then behind the door rubber the other side - just lift that with your fingers & the cable sits behind it.
Then drop the lower glovebox & open to expose the fuse box - do this by pressing down on the sides of the hinge things - as per the instruction manual - sorry for the blurred photo -
You can then push the side panel out -
you can remove that side panel completely with a bit of twisting, then route the cable into the fuse box area and replace the panel.
Fitting it to the fusebox, I used a mini piggyback fuse and as there was nowhere easy to bolt an earth to, I used a crocodile clip mount the metalwork.
I can't remember which fuse I used, but you can make it out from the blur maybe - but it was an ignition live one rather than permanent.
From the outside you can hardly see it - my telepeage tag is more of a distraction -
I hope that helps Thumbs Up
Post #327514 12th May 2015 8:32pm
tidy install Alistair.. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #327523 12th May 2015 8:41pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Thumbs Up Thumbs Up Yes very tidy job. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #327584 12th May 2015 10:56pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Your thumb looks sore. I bet the FF was the culprit.... 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #327597 12th May 2015 11:54pm
Embarassed I wondered who would be the first to spot that
It didn't particularly hurt & doesn't now - but does look a mess Big Cry
Not a FFRR related injury - caught between door & frame
Post #327618 13th May 2015 9:00am
cripboy
Scotland 2015 Range Rover Vogue SE SDV8 Corris Grey
great install, will follow suite I think.
Keith Regards
Keith
Post #327643 13th May 2015 10:15am
Badger
United Kingdom 2018 Range Rover Autobiography 2.0 PHEV Carpathian Grey
No way was I touching the trim in my RR Autobiography, so I used eric at www.dashwitness.com and he arranged the Blackvue cam and a very professional specialist fitting service who came to the house and did it. Discount on the car insurance now, yippee!!
Post #327972 14th May 2015 8:40pm
Is it neater than mine ?
How about some photos ?
Post #327974 14th May 2015 9:19pm
ebajema
How is the view Alistair ?? Since the wiper doesn't seem to cover the entire lens area or is that just the angle of the shot ??? MY 2010 5.0 SC Galway green and sand interior!!
Post #330016 30th May 2015 8:22am
I moved it down and in a bit yesterday - I was picked my up too much of the blacked out area - it was clear enough, just irritated me - if I moved it more to the passenger side I lost the drivers corner of the bonnet
Post #330044 30th May 2015 12:41pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
nice install Alistair, I did a similar thing on my old L322 (the wire was a bit more difficult to route) but I was dreading doing it on my 405 thinking the trim was going to be a lot more fiddly to get off....and of course breaking something on my new pride and joy Rolling Eyes
Post #457585 17th Nov 2017 10:44am
mattl
United Kingdom 2017 Range Rover Autobiography SDV8 Indus Silver
Great post thank you, I just installed my garmin in the same position, only draw back is I cant see it but it keeps chirping for speed camers etc! Smile
Post #458239 22nd Nov 2017 6:10pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
On the positive side you are road legal if you have one with a visible screen as you aren't supposed to be able to view them on the move I understand. I have mine mounted behind the rear view mirror for that reason.
Post #458249 22nd Nov 2017 7:38pm
the screens can be programed to switch off after about one minute so staying within the law. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #458255 22nd Nov 2017 9:03pm
