Home > Maintenance & Mods (L322) > Under Seat First Aid Box.
Zirconblue
So the under seat first aid kit is no longer available from Land-Rover.
But as you know the L322 shares lots of bits with the 1st generation BMW X5.
So i took a punt and ordered the first aid box from an X5, it fits perfectly.
So you need two parts;
The actual Box and the mounting bracket.
The mounting points under under the front edge of the seat, there is a third one in the middle just a bit further back, offer up the bracket to the front two and it's obvious where the rear one is. They're about 6mm diameter, and not threaded, but they're only pressed steel so i just screwed some M6 bolts in and let them cut their own thread.
Bracket in situ, the box just pushes onto it with a firm shove.
The finished result. You can use it for storing various small oddments in instead of a first aid kit if you like.
I used BMW Parts;
52 10 7 045 018 Which is the mounting bracket
52 10 7 044 958 Which is the actual box.
The pair of them cost me £42 from a BMW dealer.
You can also add;
51 47 7 158 344 Which is the pouch filled with first aid supplies to go in it, but it's normally cheaper just to make your own up.
Post #329941 29th May 2015 5:50pm
mjdronfield
Looks good.
I am still wondering about that mod.
Was mentioned in a thread I did a few years ago ;
http://www.fullfatrr.com/forum/topic9811.h...w+upgrades
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #329950 29th May 2015 6:46pm
Zirconblue
It does make use of other wise wasted space.
I've ordered the fire extinguisher kit too to see how that works out. It's half the price of the land Rover one!
Post #329967 29th May 2015 8:04pm
mjdronfield
And I dare say it will handle better and be lighter than the Land Rover offering, but somehow won't feel as nice Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #329970 29th May 2015 8:14pm
Zirconblue
There's also a rumour the fire extinguishers supplied to Land-Rover were nobbled so they wouldn't put a fire out, in the hope that all the L322's would burn out and not compete with BMW cars. Laughing
Post #329973 29th May 2015 9:05pm
Its a good mod, I fitted one under the drivers seat, already having one under the passenger side. .
Post #330039 30th May 2015 11:54am
Perfect storage space for hiding that small packet of Jelly Tots Laughing Laughing
Post #330045 30th May 2015 1:18pm
Weegie
Re: Under Seat First Aid Box.
Zirconblue wrote:
I used BMW Parts;
52 10 7 044 958 Which is the mounting bracket
I believe the mounting bracket is P/N 52 10 7 045 018.
However, can you tell me where you got them, please? I have searched on the web but they do not come up on the web for France. The only listings are for UK and, as they are BMW UK sites they will not ship to France. Presumably because they expect BMW France to supply. As said, can't get the part numbers to come up for BMW France.
The only other one that came up was in Poland but my Polish isn't up to it. I never got beyond "Cherry Blossom, Kiwi, Dark Tan." Embarassed Very Happy
Regards John
GAP iiD BT
Post #330053 30th May 2015 3:15pm
Zirconblue
Thanks for pointing that out, i hadn't noticed i'd typed the same part number twice i've just corrected it.
I bought them from BMW direct on ebay, however they just charge the same retail price as the BMW dealer then add a couple of pounds for postage.
I would expect the part numbers will still be valid at your local BMW dealer, they should be the same part numbers world wide. The local dealer might even be able to give a small discount. If they aren't just ask your local dealer for a first aid box and bracket for an X5 (E53)
Post #330055 30th May 2015 3:39pm
Weegie
Thanks for that. I will have to visit the local BMW dealer. Don't hold out much hope of discount over here. Sad John
GAP iiD BT
Post #330056 30th May 2015 3:52pm
Zirconblue
Perhaps, but even so it's unlikely to be more expensive than in the UK.
Post #330064 30th May 2015 5:11pm
GGDR
Just dragging up an old thread - this is very cool, but I can't work out am I looking at the front or the back of the front seat?
Greg Cheers, Greg
Post #454760 21st Oct 2017 10:45am
mjdronfield
It’s from the front I believe, but our cars are too new... it’s for the BMW Seats, but might be hackable.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #454769 21st Oct 2017 11:25am
