Home > General (L405) > 5.0 SC Driving Differences |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
I don't think there are any differences in brakes (only 3.0 seems to have smaller front discs) or suspension. In theory the SC is slightly lighter than the SDV8 but that can be all about options and trim. On the road differences seem small, maybe sc turns in a bit better, and that the sc squats down more under hard acceleration, no surprises there really as both have active dynamics.
11th Jun 2015 5:29pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Thanks Nick.
12th Jun 2015 11:52am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2521 |
Assume the anti-roll, damping etc. calibration will be different due to the lighter engine. As Nick says, you would expect it to be a little lighter on its feet because of that (similar to TDV6/SDV8 differences). |
12th Jun 2015 12:03pm |
I am a petrolhead too and am pretty sensitive to handling I can feel the difference in damping setting, tyre pressures etc on my MX5 track day car). There is a big difference from 3.0 to 4.4 emphasised by the active suspension fitment on bigger engine. The handling differences are very much smaller between 4.4 and 5.0 (I have driven 45k miles in 4.4SDV8's). I've only had my 5.0 for 2500 miles and it takes a little while to get past the really noticeable differences such as initial impressions of less torque and busy gearbox, the OMG when you stab at pedal expecting turbo lag, NVH and increased familiarity with petrol retailers. To really quantify a difference you would need to back to back drive the same corners, or just maybe ask someone with the full diagnostic kit to see if there is a separate dynamics setting for the SC.
12th Jun 2015 12:37pm |
Yes, I probably didn't phrase that very well - any differences due engine weight are no doubt far less obvious when both have active anti-roll. |
12th Jun 2015 1:52pm |
Hi Trommel,
12th Jun 2015 2:45pm |
Thank you both, Im considering a tune to reduce turbo lag and give it some more oomph, that may well be the best of both worlds then?
12th Jun 2015 8:24pm |
Aeroresh Member Since: 31 May 2008 Location: North Wales Posts: 137 |
If youre looking at tuning the sdv8 DMS is your friend '14.5 SDV8 Nara Bronze for sale
13th Jun 2015 7:34am |
No remap is going to reduce turbo lag though. |
13th Jun 2015 10:21am |
Its been suggested that it can be tuned out somewhat. Not removed but improved, don't you agree? |
13th Jun 2015 11:09am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7785 |
It cab definitely help - on my 3.6 there was a low end flat spot that a BAS remap smoothed out and made it much smoother (and quicker) off roundabouts.
13th Jun 2015 1:39pm |
I think you'll maybe find the front end suspension setup is the same between them but the firmware for the active suspension is different to account for the weight difference but also more likely to account for expected driving styles of the vehicles as the sc is more likely to be seen by purchasers and owners.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
13th Jun 2015 10:20pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
My old 3.6 was mapped by BAS too and the lag had almost been eliminated... |
13th Jun 2015 11:41pm |
Thanks for all the comments, I came out of a 2011 Cayenne Turbo so can feel the lack of low down pull. When the SDV8 gets into its stride in manual mode it pulls well and I wonder if the extra 100 Nm of torque and reduced lag might help get the best of both worlds - a much nicer car to drive overall and sit in but with a performance not a million miles away from the Porsche in Norma driving mode (not sport which was just insane).
14th Jun 2015 10:17am |
