Home > In Car Electronics (L322) > Access mode button problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
that switch only works at a certain slow speed...if it doesnt work at all then i suspect the switch is faulty or the connector has come loose or possibly the wiring is broken..
7th Jul 2015 5:54pm |
jamesbilluk Member Since: 27 May 2015 Location: Worcestershire Posts: 46 |
Hi Stan,
7th Jul 2015 6:02pm |
nice one james ... - .- -.
7th Jul 2015 7:20pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Im pretty sure that if you press the button, the lower height indicator will flash until you get to the speed where it can drop it to that level. I use it all the time coming into my drive coz I'm a short arse and need it low to get out Got - 2017 SDV8 Autobiography in Loire Blue
7th Jul 2015 8:01pm |
Many thanks, I'll have a check tomorrow when coming to a stop.
7th Jul 2015 10:24pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7927 |
I've seen a couple that the button is stuck because the switch surround hasn't been fitted properly, the button should move a small amount when you press it, if it doesn't move at all then it's probably the above... Pete
7th Jul 2015 10:33pm |
^ you can also set it from the height selector button behind the gear stick Got - 2017 SDV8 Autobiography in Loire Blue
7th Jul 2015 10:49pm |
Hi Pete, Just been out to have a look now, the button seems to move nicely when pressed, when pressed it seems like its not connected to anything.
7th Jul 2015 11:14pm |
That's a shame, it's a cheap fix...
7th Jul 2015 11:20pm |
Markbhai Member Since: 05 Jul 2015 Location: bradford Posts: 20 |
Just to check James that you are not being a dumb as I was...the doors need to be closed for it to work.
9th Jul 2015 8:44am |
Doors all seem to be closed,
9th Jul 2015 11:16am |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
Have you had the drivers door card off recently
9th Jul 2015 1:13pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I'm not really sure what the point of that button is?
9th Jul 2015 5:05pm |
