Home > Maintenance & Mods (L322) > Is this really a turbo actuator fault........
Or something else? This mostly happens when starting the car and the driop in boost pressure is accompanied by the dreaded "ENGINE SYSTEM FAULT"
[/img] Got - 2017 SDV8 Autobiography in Loire Blue
Post #337903 19th Jul 2015 10:37am
Have you checked the actuator to see if it is sticking? a common problem with them
Post #337908 19th Jul 2015 10:54am
Yes, checked and lubricated some time ago. Didnt seem to be stuck in any way but it's definitely getting worse. Got - 2017 SDV8 Autobiography in Loire Blue
Post #337912 19th Jul 2015 11:03am
could be a faulty boost pressure sensor? Definitely seems to drop out rather than decrease slowly. There is nothing that can't be fixed with a hammer😜😜
Post #337916 19th Jul 2015 11:14am
^ Is that something that can be replaced on its own?
I should also add that the EGR pressure is the same on both banks, so I hope that rules them out. Got - 2017 SDV8 Autobiography in Loire Blue
Post #337919 19th Jul 2015 11:20am
Mikey
You have either 1 actuator seized, a wiring issue to the actuator, or a faulty actuator
Unfortunately, the L/H turbo is a complete Censored to get at, to check anything...
Post #337927 19th Jul 2015 11:56am
Thanks Mikey, is this showing at the LH turbo? When the Indy checked it, they said it was the RH (o/s) that was flagging an error? Got - 2017 SDV8 Autobiography in Loire Blue
Post #337930 19th Jul 2015 12:05pm
Mikey
It is the R/H Embarassed
Wooly head syndrome is in full effect. So used to it always being the L/H one at fault Rolling Eyes
Anyway, that makes things easier. I have seen the wiring fall out of the connector, causing the turbo to give 1 reading, and one reading only, and not move at all. Check that first
Does the actuator try and move through its full sweep? Someone switching the ignition on and off while you are underneath may help
Post #337933 19th Jul 2015 12:11pm
Phew! That's a relief.
The actuator was moving freely and did go through a "full sweep" when the car was switched off and on. Would the position of the actuator change when the boost pressure drops like this?
How much resistance should there be in the actuator when the car's switched off? Should it be totally free of any resistance? It moved but it needed some effort to move it up and down but it certainly wasn't stuck. Got - 2017 SDV8 Autobiography in Loire Blue
Post #337935 19th Jul 2015 12:17pm
Mikey
You are not measuring boost pressure in those graphs, that is only the actuator position of both turbos.
They should both move freely, with little, to no resistance with the ignition off. With the ignition on, they will be fairly stiff, but should always return to its "rest" position
Bear in mind, that even though they have been freed off, they do have a tendency to stick shortly afterwards, and may require another session of lubrication and moving them up and down
Post #337948 19th Jul 2015 12:58pm
Thanks Mikey, I do have the actuator repair kit, which is essentially a new actuator arm. Would it be worth doing this before considering the whole turbo! Got - 2017 SDV8 Autobiography in Loire Blue
Post #337951 19th Jul 2015 1:11pm
Mikey
I can't picture the turbo ATM. No idea what access is like.
I'd still be lubing and freeing it off. If it cures your issue, then look into fitting the repair kit as a long term fix Thumbs Up
Post #337953 19th Jul 2015 1:14pm
Interestingly enough, drove to Liverpool and the problem seems to have disappeared! Rolling Eyes
maybe it just needed a long run............ Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #338294 21st Jul 2015 11:50am
Zirconblue
was probably just the inlet tract clogged up with soot/oil sludge.
Post #338303 21st Jul 2015 12:34pm
Can't beat the old Italian tune up! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #338318 21st Jul 2015 1:11pm
