Home > Maintenance & Mods (L322) > Slight vibrations at 2000-2300 rev range 3.6 TDV8 |
Sounds more like an dirty injector problem, run a couple of tanks with injector cleaner and see if it improves. There is nothing that can't be fixed with a hammer😜😜
26th Jul 2015 8:47am |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 242 |
Will try and report back! Thank you! |
26th Jul 2015 9:07am |
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 |
I had the same thing, the vibration was very slight , but definitely there around 2000rpm.. The vibration pretty much disappeared after I had the transmission mega flushed, and completely disappeared when I changed the diff oils.. Maybe something to look into.. How many miles has yours done, and has it had a transmission fluid change.. |
26th Jul 2015 12:30pm |
