Home > Maintenance & Mods (L322) > Advisorys from inspection
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Took mine in today for the break recall & got a call to say that's all done sir. Thumbs Up
Then the bomb shells Censored
2 advisorys Censored Censored
1) oil leak from turbo return(?) it's not not the part it's the 8 hours labour sir ££££ Shocked I explained they have already done 2 leaks in this area as previously had an oil cooler & pipes before & surely warranty? Turns out there's an outstanding bulletin for it so done again free either way.
2) front disks below serviceable level?? Done 6k since buying used approved, surely can't have done a set of disks from approved used level to unserviceable in 6k?
They are asking the question but cross yer fingers for me folks... 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #340661 3rd Aug 2015 9:58pm
RJH
Just seen an email they sent me with a video of the inspection (which is pretty cool) & also says may be sump related but left turbo leak is 1st job & see what happens.. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #340666 3rd Aug 2015 10:02pm
CEEGEE
Typical - use a recall to drum up business Whistle
Post #340668 3rd Aug 2015 10:05pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
My list after the health check came to nearly 3k!!
CV boot.....370
Brake back plate....340
New wheel due to inner kerb damage....578
New front discs.......380
Inner CV JOINT......340
Oil leak, investigation required.....78
Can't remember the rest.
Post #340689 4th Aug 2015 7:07am
Zirconblue
Re: Advisorys from inspection
It depends how hard you are on your brakes. Estimating how much life is left in brake discs isn't an exact science, they may well have been sound when it was sold to you.
Post #340727 4th Aug 2015 1:53pm
I thought you measured the thickness of brake discs in order to determine their suitability for use.
Minimum disc thickness is specified by manufacturers.
Discs are either above the minimum thickness or not.
You have the choice of replacing them earlier but if they are down to minimum specified thickness or below they should be replaced.
Post #340728 4th Aug 2015 2:00pm
Zirconblue
exactly, but they may well have been above the minimum thickness 6000 miles ago when the car was sold, estimating how much longer they would last before going below the minimum isn't an exact science.
Post #340730 4th Aug 2015 2:06pm
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
They did that to me and I left it on the reception desk. Two days later it arrived in the post. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #340739 4th Aug 2015 2:56pm
RJH
I'd have thought approved used would still have a reasonable amount of service left in them. It's not the end of the world just didn't expect to be replacing breaks already.
PaulB - ouch!!! Thank Censored I have a warranty, wouldn't wish a quote like that on anyone. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #340759 4th Aug 2015 6:35pm
RJH
Just found another thread where Ryan quotes the disks must be less than 50% worn, so disks every 12k seems very short service life? 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #340760 4th Aug 2015 6:41pm
Zirconblue
Well that's my point it's difficult to estimate the service life left in them. The technician basically just has to make a guess, they may well have seemed like they had a reasonable amount of life left in them.
They are hard on their brakes, it's a 3 ton car before you tow anything, and being an automatic they work the brakes harder than a manual box would. It also depends how you drive.
Post #340761 4th Aug 2015 6:42pm
RJH
Fair points zirconblue. don't really charge round in it, blow cobwebs out on motorway each week but mainly A/B roads daily.
Have to see what they come back with & what will be, will be Thumbs Up 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #340773 4th Aug 2015 8:08pm
awillia3
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
I took my BMW in for a recall - and they gave me an estimate of £3K for "other items" which they suggested I had done:
Break pads all round
front disks
2 tyres
2 lower arms
back box
Handy to have a list of items, just done it myself for around £500!!! Thumbs Up
Post #340786 4th Aug 2015 9:40pm
RR2008HSE
When I bought my L322 three years ago, I was advised that the brakes would need doing 'soon.'
I just had them done a few weeks ago as they were approaching the limit (but had not yet gone over it). That a good, long time from the first warning.
Post #340787 4th Aug 2015 9:45pm
Zirconblue
That's the way i look at them, it's a handy list of jobs to do. And you can judge whether it's worth doing yourself, taking elsewhere or just getting them to do it based on the price.
Post #340790 4th Aug 2015 9:59pm
