Home > In Car Electronics (L322) > dab ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
when DAB was introduced in the FF (2009-) it was on a different bit rated MOST system hence the non retro fit to the 2005-2008 models.....if the early jag stuff uses the same bit rate as ours then its feasible that it might work.. ... - .- -.
18th May 2015 7:10am |
^as a starting point before booking it in, I would check all the connections in the passenger side read cubby, where all the gubbins is located. Intermittent fault could be a loose connection somewhere. Check the fibre optic wires to and from the telephone module, as if these have been damaged it can cause the unit to falter. There is nothing that can't be fixed with a hammer😜😜
2nd Aug 2015 9:31am |
Wheeley41 Member Since: 01 Aug 2015 Location: Liverpool Posts: 2 |
Thanks norternmonkeyjones i will try that and repost my findings , ta |
2nd Aug 2015 10:12am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Does the 2005-2009 Range Rover use MOST or D2B?
5th Aug 2015 9:49am |
MOST....
5th Aug 2015 9:56am |
So the Jaguar route is out then, the Jaguars use the higher bit rate MOST receivers then have a gateway module to step it down to the lower bit rate D2B which the car uses. |
5th Aug 2015 10:35am |
