Home > Maintenance & Mods (L322) > IID with engine running |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
It will not work with the engine running sir
12th Aug 2015 10:46pm |
Billydun34 Member Since: 04 Sep 2014 Location: Aberdeenshire Posts: 45 |
Thank you kindly ill get the charger topped up first then |
12th Aug 2015 10:49pm |
12th Aug 2015 11:00pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Just don't leave it connected unless it has a supply mode. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
13th Aug 2015 10:14am |
Excuse my ignorance but what do you mean buy a supply mode? |
13th Aug 2015 9:30pm |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
many of the battery maintainers (like some of the ctek range) have supply mode, a regulated 13.6v output which is useful to retain radio memory when the battery is removed |
13th Aug 2015 9:56pm |
As above, but the function is also of great use during ECU flashing.
14th Aug 2015 8:38am |
Thanks for clearing that up guys, so i take it if i purchase a CTEK MXS 7.0 that will do the job? |
14th Aug 2015 8:52am |
The BT module is quite a long flash, and they're quite fragile, so I would be inclined to go for the jump leads option, if possible, or a more powerful charger. The MXS 7.0 would certainly help though, vs the battery alone. Obviously, you'll understand, I can't make any guarentees. Visiting from DISCO3.CO.UK
14th Aug 2015 9:21am |
