Home > In Car Electronics (L322) > after contact 12v & inside 12v |
Ibartsimp Member Since: 25 Dec 2012 Location: Bordeaux, France Posts: 197 |
Hi There, I have 2 things I want to do inside my range.
14th Aug 2015 10:38am |
ps: not sure this topic doesn't go into the In Car Electronics section. 2008 TDV8 VOGUE - Buckingham Blue on Sand |
14th Aug 2015 10:42am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7782 |
For the second one - inside the car - I would get a Piggy Back fuse and run a cable from a switched live connection in the fusebox behind the glovebox.
14th Aug 2015 10:50am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34933 |
moved.
14th Aug 2015 10:55am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
I wouldn't try connecting your tracker to the outside air temperature sensor wiring, this is fed from the ac ECU and you may well upset the ECU.
14th Aug 2015 11:03am |
thanks for the swift answers
14th Aug 2015 11:04am |
no its an ignition feed and is live when the engine is running..
14th Aug 2015 11:07am |
good. reading through right now. 2008 TDV8 VOGUE - Buckingham Blue on Sand |
Powerful posted some useful videos here that may help with taking pieces out of the dash & running cables. |
14th Aug 2015 11:15am |
@cam-tech-craig yes, but the courtesy mirror is a high point to hook from
14th Aug 2015 11:39am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7915 |
Why do you want a tracker to have a switched live, doesn't it need to be live all the time, mines got a battery backup but I'd still want it live all the time in case it's a while before you notice the car has been nicked...and personally I'd put it inside the car where it will have a kinder life and not be exposed to the elements....
14th Aug 2015 11:47am |
@haylands after contact not to drain the battery but if the drain is minimal, then I'd be happy to put it on an always live wire.
14th Aug 2015 12:27pm |
after inspecting the characteristics, I guess you're right in saying it should be in a dry place.
14th Aug 2015 12:47pm |
Inside the car should be no worse than in the engine bay - it's still surrounded by metal for a GPS signal....
14th Aug 2015 12:56pm |
