Home > In Car Electronics (L322) > MK3 nav system dead?
Chasazim
Australia 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hi guys and girls, i need help and guidance please, i wanted to upgrade the firmware for my nav system, after many attempts i managed to burn a disc with the V32 update for RR, the unmodifiedversion available from Bimmerfest, loaded the disc and the update started, this is where problems started. The program ran and then noted there were faults on the disc and to remove it, this i did and replaced the map disc. The screen seemed to reboot and appeared but blue in colour, i thought as itwas supposedto include night visability it was ok. Turned settings to locate navigation and there was none,???went to the back and the nav.unit was off?? Everything else is working, radio cd, etc, didthebattery disconnect, nothing, anything else i can try? Oh yesandnowi can change the colours of the screen Shocked Big Cry Bow down
Post #344964 29th Aug 2015 10:09am
Chasazim
Just as an update, there is still power at the nav unit in the back as i noticed there is a light on the eject button but the little red power light is off. I notice some have read my post but no answers yet, Shocked come on guys youcan do better i am sure Thumbs Up
Post #344993 29th Aug 2015 12:28pm
mjdronfield
Can't help directly as I have the mk4 unit.
Is anything on here any use ?
https://bmwnavigation.co.uk/installation/mk3-mk4/ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #344994 29th Aug 2015 12:39pm
Chasazim
Thanks for the link, i have searched through most already, having nothing to do and reading up on all those easy updates is what got me in the situation i am in Censored any one else?? Bow down Bow down
Post #345003 29th Aug 2015 1:11pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Apologies if you've already tried this but are the connections at the back of the satnav drive fully seated? I've had a problem in the past where the drive had power etc but no feed and it turned out one of the connectors was ever so slightly loose.
Might be worth trying to burn a new disc and see if that helps. They are fairly problematic though if they don't update first time though.
There is a guy on UK Ebay who fixes the Mk3 and Mk4 satnav units - might be worth dropping him an email to see if he can help you remotely first? I used him when my update for a Mk4 failed. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #345007 29th Aug 2015 1:31pm
nicksaab
Just to add to this, I remember being told the Mk3 units will lock themselves if the firmware update isn't applied absolutely correctly - i.e. format, mode etc.
I think it can be unlocked if you burn another disc with the firmware on it again - might be worth checking on the BMW forums for the settings for burning the disc Current Fleet:-
Post #345008 29th Aug 2015 1:39pm
Chasazim
I will have to get the disc out first, but a problem i see is there is power to the unit but it is not booting up, will keep trying, at least i now have something to do
Post #345009 29th Aug 2015 1:40pm
nicksaab
Sounds like firmware is locked if you have power.
On the front of the drive there is a little pin hole - if you push a pin into it that is the manual eject release - should allow you to get the disc out Current Fleet:-
Post #345010 29th Aug 2015 1:42pm
nicksaab
Actually forget that - not sure there is a manual release on the satnav drives.
If you press and hold the eject button and listen to hear the disc - when it stops making a noise release and press again, should eject the disc. May have to hold for a while Current Fleet:-
Post #345011 29th Aug 2015 1:50pm
Chasazim
1 step at a time Very Happy got the disc out. Still no power on the power light, but the light on the eject butten flashes regularly at one minute intervals, as you say a firmware problem, so ifi can find something on the bmw sites that i can access, a lot of the links provided for firmware updates seem to be dodgy as my browser wont give me access Rolling with laughter
Post #345012 29th Aug 2015 2:31pm
Chasazim
WhooWhoo success, i love my Landy and i hurt when something goes wrong, but i rejoyce when it is fixed, so now its a glass of red and then off to bed, thanks for the help.
Post #345019 29th Aug 2015 4:05pm
Steve_B
United Kingdom 2004 Range Rover Vogue 4.4 V8 Santorini Black
Hi. I know this thread is very old but can I ask where you got the firmware from?
Post #498524 14th Dec 2018 12:49am
