Home > Technical (L322) > Headlight height adjustment stuck! |
Pazuzu Member Since: 02 Mar 2009 Location: Ashford, Kent Posts: 40 |
Hi chaps,
6th Mar 2009 9:08pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6365 |
if you haven't already try downloading the RAVE L322 workshop manual. This should detail how to dismantle the headlight and adjuster.
7th Mar 2009 11:28am |
Got the manual and it shows exploded diagrams of the parts but no 'how to' in terms of removing them unfortunately.
7th Mar 2009 12:23pm |
TRY THIS - GOT IT FROM ANOTHER SITE
7th Mar 2009 1:17pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
to remove the headlamp you remove the grill be carefull as the temp sensor is atached to it , remove the 2 top bolts and the 1 on the inside edge hidden by the grille , remove the big plug at the rear and gently wriggle out it worked for me onto no6 Range Rover
7th Mar 2009 2:15pm |
Aha, I'd removed the grill but hadn't seen the extra bolt. I'll have another go in a minute. Cheers! Phil |
7th Mar 2009 3:15pm |
