Home > Maintenance & Mods (L322) > Retrofitting fitting paddle shift to a 2010 5.0 Supercharged |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 |
Thank you all for your help, my Ecu needed a re flash as the firmware was January 2009 version. Patrick from GAP was most helpful as my IID tool also needed an update to do the re flash. Adaptions all reset and paddles now working. A modification well worth doing for little cost.
25th Aug 2015 8:10pm |
Bodsy Member Since: 10 Mar 2011 Location: Shropshire Posts: 45 |
I don't think the paddles update can be applied with the Faultmate (I have a Faultmate and an IID Pro tool). It's a specific variation that Gap have made to get the 2012 paddle software working on 2010-2011 cars. |
25th Aug 2015 9:10pm |
Well there is my excuse to by the IID tool then MY 2010 5.0 SC Galway green and sand interior!!
26th Aug 2015 4:08am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3646 |
All the bits should be here next week, paddles from Dan and the cable from eBay. So its definitely on my list of things to do now Geoff |
30th Aug 2015 11:19pm |
I did have a thought, dangerous I know, is it necessary to completely remove the steering wheel or does it just make things easier. I was confused about the cable and the rotate through 180 degrees stuff but I guess this all becomes clear when it's facing you. Geoff |
31st Aug 2015 9:08am |
SCPB Member Since: 16 Jun 2015 Location: Surrey Posts: 72 |
Yes the wheel does need to come off to swap the rear of the two spokes for the paddles. 2010 5.0 SC Autobiography |
31st Aug 2015 11:47am |
Right, got all the bits, battery disconnected but I can't shift the switch packs and the airbag. Is it just a case of more brute force, I have already used plenty to no avail. I have a steel rod that fits the holes pretty much exactly but you can move it up, down and sideways. The powerful video suggests you can feel that you are pushing against a spring mine feels like you are pushing against something solid (and I have been pushing pretty hard) is there a knack to it or am I doing something wrong? Any help appreciated Geoff |
16th Sep 2015 3:42pm |
Yes had the same problem myself, don't force it.
16th Sep 2015 3:51pm |
Got it, the rod I was using was too thick because although it fitted through the outer plastic hole it was too big a diameter for the inner one, used a smaller diameter screwdriver and it worked fine, blade needs to be horizontal not vertical though and yes there are guides.
16th Sep 2015 5:32pm |
Its best to not worry about the colours, just line up the two female plugs with the notch in the same orientation as if you could actually join them. Then put the four cables / plug into the plug coming from the paddles and before you connect the other end of the lead into the steering wheel female socket, as if you were just using the four wires as an extension; just rotate the plug 180 degrees and insert it. In reality what you have done is reversed the four cables running from right to left to left to right.................. not sure if that helps.
16th Sep 2015 7:11pm |
Got it thanks.
16th Sep 2015 8:22pm |
Looking forward to hearing the result, please take plenty pictures especially the connectors MY 2010 5.0 SC Galway green and sand interior!!
17th Sep 2015 6:29am |
Right I got the request for photos too late for dismantling but I took some while mantling - is that a word?
17th Sep 2015 11:19am |
g1968g Member Since: 24 Aug 2013 Location: Fife Posts: 89 |
What are the actual benefits of having these paddles. The gear change isn't exactly quick.
17th Sep 2015 7:28pm |
