Home > Technical (L322) > TD6 2004: Very slow acceleration |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Check the small pipes to the vacuum reservoir on the inside wing above the turbo. If they are cracked, perished or come off then it wont pull under a heavy load.
21st Sep 2015 7:35pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
Fuel pump fubar'd I would imagine... |
21st Sep 2015 9:55pm |
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 |
replace fuel filter and then check inline pump under L.H rear floor infront of rear wheel |
22nd Sep 2015 12:33am |
Back in the day, when owners used to put petrol in TD6's by mistake! It used to up the pumps. I can't remember which pump used to give your symptoms... One used to stop it starting, one stop it running and one stop it revving... Maybe do some googling as to which pump does what sir... |
22nd Sep 2015 8:09am |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
Thank you, guys. I have searched based on your advice and read some of the other threads. My symptoms seem to be consistent with the secondary fuel pump failure. I have ordered a new one and will keep you updated.
22nd Sep 2015 3:54pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Hopefully you've sorted it but I had exact same symptoms as you which turned out to be bad fuel.
22nd Sep 2015 5:58pm |
Ensure to do the filter also, or else you will be doing another pump in a few months! |
24th Sep 2015 2:29am |
I replaced the filter last week with no difference in performance. Today the pump finally arrived, which I replaced without much difficulties thanks to the instructions in the wiki here. This solved the problem and the car runs fine again.
5th Oct 2015 6:43pm |
