Home > Technical (L322) > fault codes ?
33sport
2007 Range Rover Vogue TDV8 Stornoway Grey
fault codes ?
Can anyone help and explain (or had the same codes) what the following fault codes are and how serious they are, and what remedies/action I need to take. Question
PO23D manifold absolute pressure
PO196 Engine oil temp sensor
PO2A0 Cylinder 2 balance
PO29C Cylinder 1 balance
Post #351258 8th Oct 2015 5:53pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
You have a scanner?
Cleared the faults?
Did they come back?
Post #351323 9th Oct 2015 7:15am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
^----- +1 for what @RR_P38 said
Clear faults, go for a drive for a while and recheck codes.
If car appears to be running well they could be old codes that were never cleared Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #351337 9th Oct 2015 9:22am
there's a link in the wiki to a fault code site, might help.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #351339 9th Oct 2015 9:27am
Lost for Words
Are you getting any symptoms?
Black smoke for instance? If so, start by checking your intercooler hoses. Thumbs Up
Take a look at the EOT sensor data and the injector values re the cylinder balance faults if you can. Wink Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #351346 9th Oct 2015 9:49am
33sport
hi thanks for the advice, yes the codes were reset and have come back. only getting black smoke when hard acceleration.
Not sure which hoses are for the intercooler? any pics or advice please. Thumbs Up
Post #351470 10th Oct 2015 8:48am
Lost for Words
These are the ones:
https://www.google.co.uk/#q=site:fullfatrr.com+turbo+hoses
Thumbs Up Visiting from DISCO3.CO.UK
Post #351497 10th Oct 2015 11:29am
33sport
Thumbs Up Thumbs Up
Post #351545 10th Oct 2015 3:32pm
33sport
took off the hoses to inspect but no splits on either, tightened up the jubilees and test drove but still smoking Confused
Post #351684 11th Oct 2015 2:35pm
Did you pull back the webbing round the passenger side upper, it normally fails under the webbing. There is nothing that can't be fixed with a hammer😜😜
Post #351691 11th Oct 2015 3:02pm
33sport
yes had a good look under the webbing couldn't see any splits, it only smokes from the drivers side exhaust ?
Post #351694 11th Oct 2015 4:07pm
