Home > Maintenance & Mods (L322) > warning gong on start up from cold but no message
Suggs
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
2002 V8
over the last few weeks ive been getting a gong go off on start up from cold, seems to do it for a few days then nothing for a few weeks, then does it again. Only from cold though and its a single chime but no warning message and everything seems fine..
any ideas
cheers
Post #357048 15th Nov 2015 12:59pm
Weegie
If you have waited till all the lights on the dash go out then confirmation that the self check has been done and all is correct.
If you start the engine before the lights go out you don't get the chime. John
GAP iiD BT
Post #357052 15th Nov 2015 2:04pm
Suggs
thanks mate, ill check that out. just strange its not happened before the last few weeks, but sounds like your could be right as i remember seeing the battery light go out just after the gong Smile
Post #357054 15th Nov 2015 2:17pm
if the temp has been below 4 degrees then you'll get that warning.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #357073 15th Nov 2015 3:53pm
Weegie
Correct Stan although, as I understand it, you can set the temperature.
I was probably confusing it with the D2. Embarassed John
GAP iiD BT
Post #357075 15th Nov 2015 4:01pm
i dont think the temp point can be set John... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #357078 15th Nov 2015 4:08pm
Weegie
I'll have to look at it. Thumbs Up John
GAP iiD BT
Post #357081 15th Nov 2015 4:21pm
Suggs
still did it today from cold after i left it a little while between ignition and starting for the lights to go out, drove 10 miles then was parked up all day on a farm, then did it again on way home only this time HDC inactive flashed up for a few seconds then went off. Drove perfect the 10 miles home then i stoped and started it again and it didnt gong. Defo only does it from cold..
been chilly around here in the sticks today but not that cold...
Post #357329 16th Nov 2015 10:16pm
I'd check the battery voltage... Thumbs Up Pete
Post #357330 16th Nov 2015 10:31pm
chex
Kenya
low temp warning? 2004 L322 V8
Post #357358 17th Nov 2015 7:21am
ebajema
It sounds like the low outside temperature warning. However when the engine is warm, the heat will get to the outside temperature sensor (when the car is sitting still) and "raise" the outside temp measurement.
I seem to remember that with the Faultmate you can play with the chime for cold outside and maybe even at which temperature you want it to do so. But not sure at all. MY 2010 5.0 SC Galway green and sand interior!!
Post #357360 17th Nov 2015 7:41am
Suggs
thanks, makes sense as only started doing this since the weather got colder. And once engines warm it dosent do it until car left all day or over night..
Post #357384 17th Nov 2015 11:36am
ebajema and chex, you still asleep this morning... Rolling Eyes
 Pete
Post #357385 17th Nov 2015 11:37am
miggit
Pete, they don't do cold in there neck of the woods, I'm not sure that they have grasped the concept Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #357390 17th Nov 2015 12:29pm
