Home > Maintenance & Mods (L322) > ZF6 gear oil. |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
Hi folks.
14th Nov 2015 6:00pm |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
If you want the genuine ZF oil for the 6 Gbox then ive never seen it in any larger sizes than the 1ltr, most on here will tell you that its the only oil you can use. Some of the power flush guys do use a different oil that is available in larger sizes .
14th Nov 2015 7:35pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Yep, 1l bottles only.
15th Nov 2015 12:07pm |
Thanks lost for words. That's a good price, I've been quoted double that. Is there such a thing as a cheap version as I want to put the best stuff in. Also any idea how much I need? |
17th Nov 2015 8:58pm |
Not quite sure what you mean by this bit? The Meyle oil is the same as the genuine ZF Lifeguard 6 - is that what you mean't? Steve @ AF sells 10 litres with the filter change kits. Make sure you follow the correct level checking procedures: http://www.disco3.co.uk/gallery/albums/use..._level.pdf Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
18th Nov 2015 10:56am |
Just to clarify I was just wondering (due to the cheaper price) if the meyle was a cheap version of the genuine stuff? I have today ordered the oil, filter etc to service my gearbox. I ordered from advance as you suggested.
18th Nov 2015 8:22pm |
19th Nov 2015 10:37am |
