Home > Maintenance & Mods (L322) > TD6 Exhaust |
What are you trying to achieve by changing it? |
28th Oct 2015 4:42pm |
jody1476 Member Since: 28 Oct 2015 Location: Chipping Norton Posts: 4 |
Hi
28th Oct 2015 5:14pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
Be aware that I believe it is now illegal to remove EGR's, and can result in a refusal to issue an MOT AFAIK. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
28th Oct 2015 5:54pm |
I'm not sure, there's nothing in here about EGR valves. I have a DPF (which if removed is an instant fail) so no smoke from mine
28th Oct 2015 6:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Have you had a DPF fitted because they didn't come with one as standard..?? Pete
28th Oct 2015 6:34pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7632 |
I didn't think testers could strip stuff down during the test, and I'm pretty sure the acoustic cover would have to come off to verify egr removal...... Could be wrong. 2011 Range Rover Vogue SE 4.4 TDV8
28th Oct 2015 6:35pm |
I assume I have as I don't get any smoke at all. MOT test on diesel is smoke test, at least it was |
28th Oct 2015 7:05pm |
It's too old for a DPF, changing the back box won't have much effect on performance and won't make it sound much different, the turbo mutes the noise anyway...
28th Oct 2015 8:39pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Your not confusing a DPF with a CAT? Yesterday I couldn't spell Engineer... Today I are one!
29th Oct 2015 1:32am |
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 |
I chopped mine off and added some pipe..sounds much better, turns heads even
23rd Nov 2015 6:02am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
You mean from this
23rd Nov 2015 8:48am |
23rd Nov 2015 6:48pm |
Are you going to share the noise with us all, or just leave us guessing?
24th Nov 2015 12:46am |
