Home > Maintenance & Mods (L322) > Gear selector issues |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
could the gear connections under neath be needing lubrication.. ... - .- -.
27th Nov 2015 3:11pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I'm thinking that Stan but was hoping this had been seen before. I read that on the petrol cars, there's a linkage mechanism bolted to the outside casing of the gearbox but it's inside on the diesels.
27th Nov 2015 3:15pm |
avoid you eyes, that hurts..
27th Nov 2015 4:02pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
You’re thinking there of the earlier models with the 5-speed transmissions where the inhibitor switch on the GM 5L40-E (diesel models) is inside the casing whereas for the ZF 5HP24 (petrol models) it’s on the outside. You have the ZF 6HP26 transmission and, as Stan says, it sounds very much like the cable clamp has seized in its hole in the selector lever underneath the car preventing it from articulating as the lever moves through its arc.
27th Nov 2015 4:06pm |
Thanks Phil, you're a champ. I'll take a look tomorrow Got - 2017 SDV8 Autobiography in Loire Blue
27th Nov 2015 5:42pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Exactly the same procedure as here: http://www.disco3.co.uk/forum/topic31656.html
27th Nov 2015 10:30pm |
Cheers Mikey. So those part numbers in that thread are relevant to my car too? Got - 2017 SDV8 Autobiography in Loire Blue
30th Nov 2015 1:03am |
