Home > Technical (L322) > Rear diff locked up 3.6TDV8? Problem.... |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
A valid coincidence with the tyres - they were fitted on the 24th of August. I suppose it is a possibility that the ECU is detecting the wheels have less traction and therefore partially locking up the LSD.
26th Nov 2015 10:55am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7944 |
Glad I've got the earlier FF then, what with less comfy seats, far more rust, diffs, and now transfer boxes filing with water the later ones seem to be a step backwards....
26th Nov 2015 11:54am |
Ah the price of us being pioneers
26th Nov 2015 12:47pm |
Maybe but I can't see it pulling in water even if the pipe had come off the breather and it was totally under water, the breather is (well should be) the only link to the outside world so water won't pour in, a very small amount may find it's way in but not enough to do much...
26th Nov 2015 7:14pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16186 |
Which leads us back to long term condensation Pete???
26th Nov 2015 7:20pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 314 |
I had those exact warning lights in that sequence, it was an abs sensor Many thanks Paul |
26th Nov 2015 7:52pm |
I agree Craig but I think there are two things going on... can't see the centre diff making the inside rear wheel skip, it would make the easiest one, the outside one, skip.... I still recon it's an ABS sensor giving faulty signals to the ECU and it's trying to lock a wheel as it thinks it's spinning, mine did the exact same thing and now Pvw10 says his did the same I'd be inclined to check them... Can you get live date from them individually on yours, I don't think the earlier ones can... mine was the nearside rear and that one does the speedo so I had a good indication of it's erratic nature by loosing the speedo and variable rate power steering... as you don't have these faults as well then I recon it's the off side rear sensor... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
26th Nov 2015 9:53pm |
Pete, with all due respect my friend, the car was driving fine when returned! The centre diff oil was badly contaminated with water!
26th Nov 2015 10:17pm |
Pete,
26th Nov 2015 11:22pm |
Sorry, read it wrong, thought it was still a problem... yep, I suppose water in the diffs and tranny box can do all sorts of things, If it's just doing it a tad then a good flush out will hopefully sort it.... I left the tide mark just above the door pocket on mine to remind me not to go swimming....
26th Nov 2015 11:33pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2318 |
Applying a vacuum/low pressure to a diff or TC is exactly the opposite to what is required to keep water out when submerged. Cooling of a diff or TC housing whilst submerged causes water to be sucked in past seals as the inside pressure lowers. Don't enter deep water with hot transmission components! |
27th Nov 2015 8:35pm |
I meant to keep condensation out, change the air in there all the time and it should work... works to keep it out of distributor caps...
27th Nov 2015 10:17pm |
Well changed the oil in the transfer box this evening and it was pretty dire. Tiny metal particles in there as well by the looks of it. Might do another change in a few weeks to see how it looks.
27th Nov 2015 11:16pm |
Hope it's OK.... Pete
27th Nov 2015 11:24pm |
