Home > In Car Electronics (L322) > Loss of screen display RR 06 L322 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34948 |
you can bypass the phone unit by using the outside part of a biro....if the other stuff then works then you have found the culprit.. ... - .- -.
15th Dec 2015 10:37am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
I would do the obvious as well, which is put the car on charge over night.
15th Dec 2015 10:52am |
honeyman Member Since: 28 Dec 2012 Location: Bristol Posts: 21 |
Hi Stan, that sounds a good idea only problem i have is that it's very difficult to pull the cables out of the socket, I have removed the small locking device in the socket, is it now a matter of pulling ??? |
15th Dec 2015 12:37pm |
havnt done it myself but have a read here,
15th Dec 2015 12:55pm |
Hi Stan ... thanks for the info most of system now working, but had to by pass mobile phone unit and the TMC XRA500031 that supplies the road info ie road traffic. I have lost the 12volt supply ( when tested on bench unit worked) any ideas. where this is fed from ?? |
23rd Jan 2016 3:26pm |
