Home > Wheels & Tyres > Do MY08 SC rims fit MY11/12 SC/TDV8? |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
I have 2010 supercharged wheels on my 2007 supercharged .
14th Dec 2015 12:21am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2323 |
Thanks. However the brakes on MY11/12 are 6-pot not 4-pot and the callipers are larger than the 4-pot. |
14th Dec 2015 2:24am |
I can look at my spare tommorow as that is the original 07 supercharged wheel and compare the inner diameter to my 10 wheels .
14th Dec 2015 4:17am |
The spokes have to clear the outer side of the calliper so measuring the rim's inner diameter is only half the question. To be sure someone would have to have fitted the particular style (RRC502690 - 9-spoke) to a MY11/12. LR didn't offer them for MY10-12 but that doesn't guarantee they don't fit. |
14th Dec 2015 9:35am |
Ok I'll look at the spokes later .
14th Dec 2015 1:26pm |
Its of no use comparing the gap between my rims and calipers with your rims and calipers as your calipers are different.
14th Dec 2015 9:08pm |
You have assumed what I was going to do .
15th Dec 2015 2:54am |
Sorry, I had confined my considerations to MY11/12 because the MY10 still had the 3.6 TDV8. However the parts catalogue shows the various rims for MY10-MY12 so except for the older style 19" which was available in the 10/12 range that is noted not to fit the 4.4 TDV8 and SC in those years, all the other 10/12 rims shown will fit over the 4.4 & SC brakes. Therefore any 20" 2010 SC rim that you have will indeed fit over mine's brakes and therefore considering any differences in spoke clearance is valid.
15th Dec 2015 4:13am |
I was just having a quick look by flashlight when the sprinklers came on !!
15th Dec 2015 5:27am |
Thanks Ian for your efforts.
15th Dec 2015 10:02am |
It's going to be at least 10 hours before I get off work and get a wheel off .
15th Dec 2015 3:15pm |
I'll take my chances and arrange to get the rim. Worst case is I'll have to return it but providing it fits the rear it will suffice. Don't bother changing wheels as I will have bought one by then.
15th Dec 2015 8:21pm |
I can confirm that these rims indeed fit over the 6-pot Brembos with what appears to be at least the same clearance as the original rims on this vehicle. |
7th Feb 2016 12:44am |
