Home > Maintenance & Mods (L322) > touchscreen display dim on startup |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
a few times now over the last 2 years , my display hasnt got to its full brightness on startup , especially if i havnt used the FF for 3/4 days..
21st Dec 2015 11:42am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
Have you tried a software update from the iid Stan? |
21st Dec 2015 12:15pm |
? more info please craig-meister... ... - .- -.
21st Dec 2015 12:19pm |
i have 'nav on the move' already
21st Dec 2015 12:34pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 691 |
Mine does that! Sometimes!
21st Dec 2015 11:44pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Mine too. But not often. I'll watch this with interest. I have the iid, so any instructions are most welcome. Cheers. |
22nd Dec 2015 12:28am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Me as well , I used to think it was the cold but clearly not the case here . Both cars have done it and it's very random so I just ignore it . Every year or so there is a post about it so it's not that uncommon but no one has ever got to the bottom of this . 2008 MY Supercharged
22nd Dec 2015 2:10am |
55palfers Member Since: 26 Aug 2014 Location: Solihull Posts: 113 |
Same problem on mine from time to time Stan.
22nd Dec 2015 9:59am |
i dont think its a big concern Mike as [you say] it will correct itself , but by switching the display off using voice command ,the display comes back straight away to full brightness..
22nd Dec 2015 10:18am |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
It could be to do with the auto light sensor that dims the screen, this time of year on these dull dark days especially if you have tinted windows the inside of the car can be pretty dark so naturally the screen will dim as it thinks its night time |
22nd Dec 2015 10:23am |
it could be but my screen is brighter than that at night than when i get the dim screen...
22nd Dec 2015 10:30am |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
I have come across a worn out dimmer adjuster on the main headlight switch module cause this
22nd Dec 2015 10:47am |
it wont be that as that dial controls the speedo/rev lighting and thats not affected when the screen goes dim...as it happens the lowest setting on the dial is still brighter than the screen when it has its hic-cup.. ... - .- -.
22nd Dec 2015 12:12pm |
DallasRob Member Since: 28 Dec 2017 Location: Dallas, Texas Posts: 10 |
Have searched the forum for posts related to this, but no luck (yet) finding a definitive answer/solution. My 2008 HSE has developed this exact problem. It has a brand-new screen from the dealer (thank you, extended warranty) AND a software fix related to the system staying stuck on the Land Rover oval while it turns itself off and on every two seconds. That problem seems to have disappeared after the software fix — but this morning, dim again on startup. The truck is parked in a subterranean garage every night and it was 50 degrees Fahrenheit in Dallas this morning. Any further info on this problem? |
25th Jan 2018 7:17pm |
