Home > Technical (L405) > INFO REGARDING ARCAN JACK PLEASE |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I've been looking at that myself in Costco, I'm of the same belief as you, if I'm only jacking up a corner of the car , I'm assuming the 2 tonne jack will be fine. I used the RR jack a few months ago and for whatever reason, the scissor jack was fighting going up to the point where the winding handle buckled under the force I had to user. LR replaced the whole jack for me but since then I have been considering that jack as it seems well buold and is great value at £90. I also noticed what appear to be lifting points under the car (4 round metal discs, presumably for use when on ramps in the dealers? Steve
4th Jan 2016 3:58am |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 654 |
Thanks Steve, I'll make some more enquiries and if I can get a result I'll come back to you. Cheers Steve |
4th Jan 2016 9:54am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
https://www.machinemart.co.uk/p/ctj3000ql-...trolley-j/
4th Jan 2016 11:19am |
