Home > Technical (L322) > front droplinks. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1245 |
If the drop links went, then other ball joints and bushes can have worn as well. Only way is to get under and check all the ball joints / bushes.
16th Jan 2016 12:23am |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
Agreed I changed my drop links and shortly after the bushes and ball joints needed looking at 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
16th Jan 2016 9:11pm |
Likely to be the bottom ball joint on the front arm these seem to be the first to go imho.
16th Jan 2016 9:17pm |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
Just had my drop links and front arms replaced following an MOT failure. All covered under extended warranty but 2011MY 4.4 TDV8 has only done 70k. As others have said, they probably won't be the only items requiring attention. The noise I was getting was a loud creaking noise. 4.4 TDV8 Vogue Baltic Blue MY11 |
16th Jan 2016 11:03pm |
