Home > In Car Electronics (L322) > Sat Nav - "Temperature Error, shutting down" |
TTF Member Since: 06 Feb 2012 Location: Wiltshire Posts: 130 |
Has anyone come across this message on the sat nav where it then completely shuts down?
16th Nov 2015 6:59pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 396 |
I've had same problem occur twice now, not straight away but randomly when on journeys.
16th Nov 2015 11:45pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 721 |
Wondering if there were any further answers to add to this thread?
14th Jan 2016 4:45pm |
More to it than that I fear. Can't be anytyhing to do with cooling fans, as it happens from cold when the ambient temp is zero.
14th Jan 2016 9:49pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
Aye, that'll be £1,300 plus vat and minus guarantee that it'll fix the problem! |
14th Jan 2016 9:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
its rare but i sometimes have a dim screen when starting up in the cold..my solution was to leave it until a re-start where then the screen would go to full brightness or use voice control to command 'display off' and then 'display on' ..this display on/off would re-energise the screen to full brightness..
14th Jan 2016 10:43pm |
Mentioned my fault to dealers when in for event service, they said it needed a software update takes 2 hours & costs £180
15th Jan 2016 12:17am |
Kieranc Member Since: 15 Jan 2016 Location: Cambridge Posts: 2 |
Hi all,
15th Jan 2016 11:04am |
I'm beginning to see a patern with this.......
16th Jan 2016 5:59pm |
Ah well, that didn't work....... So much for my 'theory'.
18th Jan 2016 10:16am |
Does anyone know where this sensor is in the unit?
20th Jan 2016 9:41am |
Finally had time to look in the boot. Took the cover off the left side and tried to eject the SatNav DVD. No joy. The slider is unlocked and the button is pressed, but the DVD ain't appearing. Tried with ignition off, ignition on and engine running. No difference.
27th Jan 2016 7:37pm |
adamjcooper1 Member Since: 08 Apr 2018 Location: cannock Posts: 2 |
Hi,
8th Apr 2018 8:10pm |
After months of investigations and trawling the web, it appears that this is not an isolated issue, but it's not particularly common either. The long and short of it is that Denso have an ambient temperature sensor located somewhere on the PCB(s) of the head unit (behind the screen). Problem is that Denso will not provide any information about the PCB design - not even to Land Rover - so we can't pinpoint the troubled component.
6th Aug 2018 2:35pm |
