Home > Technical (L322) > Spare engine wires 4.4 V8 M62 |
would have thought they would original had some sort of connector on the end, pretty sure that even LR would have put something there. There is nothing that can't be fixed with a hammer😜😜
17th Jan 2016 11:06pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
What are the colours as it's difficult to make out exactly? There is a standard as to what colour wires should be for what job although it's not foolproof.
18th Jan 2016 6:19pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 332 |
Thanks for the reply!
18th Jan 2016 9:05pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
from what I can see, you are looking at the fuel rail, on the left side, there are wires in a rubber sheath that form part of the injection loom. and there are a few plug sensors in that area. I cant go outside till weekend as too dark etc, so replying here, to bookmark. -has your car got LPG?
18th Jan 2016 11:35pm |
Hi Johnboy,
18th Jan 2016 11:46pm |
I also have lpg, if I remember, I will look at weekend. the normal fitment of lpg, involves interrupting, the injector wires. you leave then connected. as you can run the car still on petrol. these are then switched off when you run on LPG. but these wires could be extra wires from the LPG brain. (lpg ecu) mine is screwed in under the ecu box lid. these might trace back to ecu box. (square-ish black cover to left of engine) they might be extra temp sensor wires.
19th Jan 2016 12:28am |
