Home > Maintenance & Mods (L322) > Major engine oil leak 4.4 TDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
Well, I picked it up last Tuesday. Before collection the garage had the mot done and there were advisories on a slight oil leak. They said it was sorted and they'd done a service. I took it to my local Land Rover dealer this morning for a brake hose recall and they told me it had a major engine oil leak and sent me a video.
23rd Jan 2016 7:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34923 |
first thoughts are a loose or badly fitted oil filter.. ... - .- -.
23rd Jan 2016 9:04pm |
Thanks gents.
23rd Jan 2016 10:12pm |
Aparently not easy to get to
23rd Jan 2016 10:29pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
It seems to me that you've had / have a few issues with this car - surely the dealer needs to sort it ??
23rd Jan 2016 11:47pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
There is an engine oil feed pipe into the back of the EGR with a 10p oil ring seal that fails... Just a pointer for you if the oil filter housing is good... A video boroscope helps track these type of leaks down sir... |
24th Jan 2016 1:27am |
Thanks. I don't think it's a wrong un as the other bits are sorted bar the mirror glass, and that wasn't the cars fault. Juddering was rear wheel balancing.
24th Jan 2016 5:38am |
Not saying it's a wrong un mark, probably just stuff which wasn't noticed by the former keeper, most folks aren't as diligent as us forum types
24th Jan 2016 9:33am |
I put about 2 litres of oil in to get it to the max level. I know it holds 9....
24th Jan 2016 3:07pm |
Ok..... It's still on Max...
24th Jan 2016 3:28pm |
make sure to check when warm according to the manual. 3.6 cold, 4.4 warm for some reason. There is nothing that can't be fixed with a hammer😜😜
24th Jan 2016 4:13pm |
That's what I did. Never had one without a dipstick so followed the instructions.....
24th Jan 2016 4:17pm |
If I'm right the type of fitting CTC is talking about is a plastic push on one, with a squeeze release on either side, the rubber o rings in them can compress and leak, I have a similar though less messy leak on the one for the bottom of the dip stick tube on mine. I think you can just pop the o ring out an replace with one of the correct size, so if it is that which is leaking at least the parts bill would be small. There is nothing that can't be fixed with a hammer😜😜
Thats the one Mr NMJ
25th Jan 2016 12:36am |
