Home > Technical (L322) > Lights on the centre dash vents
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Driving in the dark yesterday I noticed that 1 of the dash centre air vents was lit up. The green light at the top, the white/cream light at the bottom and the knurled control. That was on the drivers side but the passenger side had no lighting at all.
I'm guessing a dicky bulb so how do I get behind to replace said bulb?
I also note that the vents at either end of the dash have no lights but having searched on here, it appears that is by design. Something to do with reflections in the door mirrors.
I had a good look at Powerfulls various videos but nothing for the centre air vents. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #368924 26th Jan 2016 6:48am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Passenger side centre vent should be lit - you have probably got a dud bulb. If you search 'centre vent removal' on here, @nicedayforit has posted a you tube link which will show you how to remove the vent to get at the bulb. Thumbs Up
The outer (door side) vents are not illuminated, personally I don't think this has anything to do with glare in the windows, as we already get the reflection of the switch pack lamps for the windows etc. My guess is that they forgot to allow for a supply when they designed the wiring looms!! Whistle 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #368960 26th Jan 2016 2:17pm
rangie47
all mine light up Shocked 2007 tdv8 se ,stornaway grey
Post #368980 26th Jan 2016 6:28pm
Dean
Scotland 2007 Range Rover Vogue TDV8 Java Black
HI all,
I have the same bulb out and have managed to take the vent out.
The "bulb" looks like a little LED - any idea of the code or any one got a useful link for what should be used to replace them?
Thanks,
Dean 2006 FFRR TDV8 Vogue
2012 Discovery 4 SDV6 GS
Post #369086 27th Jan 2016 7:57pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
On a 2010 the centre and outers have back lit knurled roller switched.
Not sure what spec / year FF you are refering too? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #369130 27th Jan 2016 10:24pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Can somebody take a pic so I know what you're talking about ?
Only the controls light up on mine
Post #369133 27th Jan 2016 10:49pm
