Home > Maintenance & Mods (L322) > Rear Washer Blocked |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34943 |
would not the washer water come out of said tube when the rear windscreen stalk is operated.. ... - .- -.
28th Jan 2016 2:03pm |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 423 |
That's how I tested it Stan; by operating the steering column control why my lovely assistant watched the tube.
28th Jan 2016 2:13pm |
ah..never done mine so i dont know how much water should come out ..hopefully someone will come along and tell.. ... - .- -.
28th Jan 2016 2:16pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Did you pull the pipe off the black elbow on the wiper motor or off the non return valve 2" further up the pipe?
28th Jan 2016 2:54pm |
Ta miggit.
28th Jan 2016 3:22pm |
It is possible to split the non return valve and clean it out...... it's not the ball bearing type.... it's got a knakered condom in it And don't stab yourself with the screwdriver, which is a lot easier to do than split the valve
28th Jan 2016 3:39pm |
I tested the flow, sans non return valve and the expected vesuvius was forthcoming, ergo knackered non return valve. Ordered 1 at Barrats for the princely sum of £8 and change.
28th Jan 2016 5:38pm |
have a look at the above fixes miggit put up, the seals go inside the motor and can be bought from a local supplier of bearings etc or off of eBay for a couple of quids. replace the seal follow the description, should take about 1/2 hour to strip and fix while you have got it off. works a treat, did mine on the 3.6 a while back and it was fine up until it was sold saves loads of cashola. There is nothing that can't be fixed with a hammer😜😜
28th Jan 2016 6:07pm |
^^ Wot he said
29th Jan 2016 12:06am |
Here you go under £2.00
29th Jan 2016 12:09am |
Well I bit the bullet and ordered a new motor from the bay for £147.50. Genuine Land Rover from the main dealer in Hull.
2nd Feb 2016 1:23pm |
