Home > Maintenance & Mods (L322) > Gearbox Megaflush |
Yes, so this issue has been done to death in many forums, especially regarding Land Rover, their warranty, ZF Gearboxes, the ZF recommendations, how other manufacturers service the same range of gearboxes and so on.
26th Oct 2013 4:12pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1491 |
I think I wll have this done. but I'm contrary so I want the megaflush AND the filter done. my question is:
26th Oct 2013 4:24pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
You must be talking about the the TD6 gear box here (Plastic pan) unless it is a later model V8 with a ZF gearbox? The early L322 V8 has a metal pan and the trans is fully serviceable, contrary to the "sealed for life" idiocy. I can most certainly confirm that there is a filter in the ZF trans, I had my hands on the old one and the new one a few days ago when I changed it. If the Diesel (GM 5L40E) box does only have a strainer this would appear to be its short coming and give cause as to why it fails at an alarming rate. Valve body wear results in debris this circulates in the trans and causes more wear, a strainer cant pick this up as it is initially very small debris. As the debris load in the fluid accumulates the trans might start to shift badly (warning) and then as the debris load in the fluid increases so does the likely hood of a catastrophic failure. A "mega flush" is a good idea for sure on the GM box. If you have a ZF box you would be mad not to get the pan taken off the "filter" changed, and the debris magnets cleaned. |
26th Oct 2013 9:45pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
Well my 6 speed TDV8 doesn't just have just a strainer! Ive opened my old one (OE JLR) today and its a filter behind a strainer!
26th Oct 2013 11:55pm |
Totally agree with what you say.
27th Oct 2013 12:07am |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
Very interesting thread this. Preventative maintenance is a good thing. As mentioned earlier, I wonder how LR would view a warranty claim for gearbox problems were they to be aware of an owner having previously commissioned a "mega flush"? 4.4 TDV8 Vogue Baltic Blue MY11 |
27th Oct 2013 12:15am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1700 |
A megaflush replaces around 98% of the old oil. A drain/sump/refill replaces around 55% of the oil. While not so much of an issue on the FFRR, it is on the TDV6 D3/RRS, and it is vital to replace as much of the oil as possible |
27th Oct 2013 8:34am |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
advantage of mega flush :changes all the tranny oil
27th Oct 2013 10:14pm |
Well,
27th Oct 2013 11:12pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 285 |
For the TD6 GM 5L40E: you can look here, also available at YouTube the second part! TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
2nd Nov 2013 9:06am |
Tang37 Member Since: 25 Jan 2016 Location: Manchester Posts: 20 |
i have just been to Quattro autocare in riccall yo19 6ql. This morning and had my gearbox flushed and all I can say is my gear changes are a lot smoother the mileage on my rr is 102000 they did not change my filter they also added two lots of dr tranny which they say elimates torque converter lock up and shudder worth putting in. They also reset the adaptation which makes the rr learn the way you drive and adjusts the gearbox accordingly.
6th Feb 2016 6:20pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2030 |
Could know how much this cost please. |
7th Feb 2016 1:48am |
Thanks for the question.
7th Feb 2016 1:07pm |
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 |
What are opinions about having the gearbox ecu adaptation reset? Quattro also reset mine when I took it in but in hindsight it might have been better leaving it as it was. I understand that it compensates for wear in the gearbox which is surely the same even after an oil change - but does it do anything else? |
7th Feb 2016 1:48pm |
