Home > Maintenance & Mods (L322) > Gearbox Megaflush |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
It comes down to experience, at the end of the day
7th Feb 2016 11:48pm |
The filter isn't really a filter. It's a coarse bit of gauze/foam, to take big lumps of debris out of the oil
8th Feb 2016 7:53am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
i suppose you flog megaflushs then Mikey ...
8th Feb 2016 3:41pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
My view is this (as regards the ZF 6-speed):
8th Feb 2016 4:18pm |
you disco3 boys stick together then.... ... - .- -.
8th Feb 2016 4:30pm |
Yep, but be assured it's not for any personal reasons. Visiting from DISCO3.CO.UK
8th Feb 2016 4:41pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
Stan I totally agree - you are spot on ! Look at it this way - Change it often - every 50K - its the same thing as flushing - FACT sometimes you can be led up the garden path ! . |
8th Feb 2016 4:53pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
Sounds to me like there is a case for both......
8th Feb 2016 5:06pm |
As above.
8th Feb 2016 5:25pm |
8th Feb 2016 7:03pm |
TDV8 at 63k miles before flush...
50k is the service interval as stated by ZF, and also states that a FLUSH is due. A simple drain and refill removes approx 4.5 litres of oil, around 1/3 of the capacity of the gearbox In no way, shape or form, is a drain and refill or even a "double flush" is the same as a power flush |
8th Feb 2016 10:11pm |
Inside the strainer within the sump pan
8th Feb 2016 10:24pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Er! The "coarse" strainer doesn't look that coarse! Previous cars:
9th Feb 2016 8:09am |
Mikey - TOP MAN Thank you for taking the time & trouble to upload pictures OK - I Totally agree with you - and you sure know what your doing. What I cant get my head around is that LR UK - service all my cars - only do for £700 a drain & fill !!!!!!!!! Is the oil that expensive - if LR did a Flush as you say - and I think you have a valid point then you are talking about over a £1000 ! Are we saying that you can do all this "at Home" now I read in the workshop manual that when refilling the gearbox the temperature needs to be at running temp so not to over fill Or is it a case of filling up with ( WHAT COMES OUT - MEASURE & PUT BACK IN WHAT HAS COME OUT. Now there's not too much I don't know about car maintenance - but this thread has got me so confused In a nut shell- I totally now see where everyone is coming from WHAT I CANT SEE AND UNDERSTAND - IS WHY LR UK - SERVICE PLAN DOES NOT LOOK AFTER THE GEARBOX OIL IN THIS WAY The Range Rover is their TOP SELLING BEST VEHICLE If after what your saying ONLY 33% COMES OUT with a Drain ! But Once again - Thank you Mickey - really appreciate all you have said & done I THINK EVERYONE ON HERE NEEDS TO COME & SEE YOU AND GET THERE'S DONE PROPERLY ! . |
9th Feb 2016 10:36am |
