Home > Technical (L322) > Limp mode help please !!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Sounds like an abs sensor or a height sensor, get the faults read and all will be revealed.... Pete
9th Feb 2016 9:08pm |
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 |
Abs sensor, that could be a thought as the dealer that sold it to me had just had new discs and pads all round the day before he dropped it off to me.
9th Feb 2016 9:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
did you set the steering parameters when you fitted the new battery?....[how to in the wiki].. ... - .- -.
9th Feb 2016 9:32pm |
Hi Stan, I am not sure as the dealer did it when I asked him to look at the faults.
9th Feb 2016 9:41pm |
can do...leave it disconnected for a few hours then reconnect and turn the steering wheel fully left and then fully right.. ... - .- -.
9th Feb 2016 9:46pm |
Stan, will I need to enter a radio code or any thing like that or just disconnect both sides and reconnect a few hrs later.
9th Feb 2016 9:51pm |
no code needed... ... - .- -.
9th Feb 2016 9:54pm |
Make sure you follow the correct battery disconnect procedure, not doing so can be expensive and dangerous...
9th Feb 2016 9:57pm |
Thank you both I will try it tomorrow. Thing is because the fault is very intermittent you can't tell if it's fixed.
9th Feb 2016 10:41pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
Where in Brizzle are you Dave? |
10th Feb 2016 12:17am |
Oh yeah, didn't notice you were down that way, pop in and see Craig, he's a top bloke who can sort it for you.... Pete
10th Feb 2016 12:55am |
Hi Craig. Live in nailsea but work bs2.
10th Feb 2016 8:16am |
Quick update, took the car to a local Indy today, he rang me and said the code was pointing to low fuel pressure. He said take it away and use it for a while, he would give me a ring when he has time to look into it more.
11th Feb 2016 11:13pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
11.5v is discharged and will affect a L322 tdv8.
11th Feb 2016 11:23pm |
